2023 Ct2535 has no front and back spotlights and radio stopped working
   / 2023 Ct2535 has no front and back spotlights and radio stopped working #1
Hunter0310
Bobcat Ct 2035
Anyone have a wiring diagram for the cab power for lights and radio. Lights stopped working and then couple days later radio stopped working. Check fuses and all are good.
   / 2023 Ct2535 has no front and back spotlights and radio stopped working #2
I had the same problem on my CT2540. The constant power pin in the connector that is located right under the step gets corroded and basically melts away. Dealer replaced it when it was under warranty. Came back in less than six months. The location and orientation of the connector allows water to fill and it gets destroyed quickly. My solution was disconnecting that wire from both ends of the connector and hard wiring them together. I haven’t had a problem for the two years since I did that.
JMR stump/trenching bucket (A53421)
JMR...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
1996 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
1996 POLAR TANK...
2010 Toyota Prius Hybrid Hatchback (A53424)
2010 Toyota Prius...
New/Unused Quick Attach Stump Grinder (A54865)
New/Unused Quick...
