2023 Ct2535 has no front and back spotlights and radio stopped working
   / 2023 Ct2535 has no front and back spotlights and radio stopped working #1
Hunter0310
Bobcat Ct 2035
Anyone have a wiring diagram for the cab power for lights and radio. Lights stopped working and then couple days later radio stopped working. Check fuses and all are good.
   / 2023 Ct2535 has no front and back spotlights and radio stopped working #2
I had the same problem on my CT2540. The constant power pin in the connector that is located right under the step gets corroded and basically melts away. Dealer replaced it when it was under warranty. Came back in less than six months. The location and orientation of the connector allows water to fill and it gets destroyed quickly. My solution was disconnecting that wire from both ends of the connector and hard wiring them together. I haven’t had a problem for the two years since I did that.
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
JNC 1224 Jump Box with Charger (A54865)
JNC 1224 Jump Box...
2012 FREIGHTLINER CORONADO 122 (A55745)
2012 FREIGHTLINER...
Kubota ZD326 60in Zero Turn Mower (A55851)
Kubota ZD326 60in...
2016 Ford F-450 4x4 Ambulance (Diesel), VIN # 1FDUF4HT5GEC45875 (A54865)
2016 Ford F-450...
