2023 Ct2535 has no front and back spotlights and radio stopped working
   / 2023 Ct2535 has no front and back spotlights and radio stopped working #1
Hunter0310
Bobcat Ct 2035
Anyone have a wiring diagram for the cab power for lights and radio. Lights stopped working and then couple days later radio stopped working. Check fuses and all are good.
   / 2023 Ct2535 has no front and back spotlights and radio stopped working #2
I had the same problem on my CT2540. The constant power pin in the connector that is located right under the step gets corroded and basically melts away. Dealer replaced it when it was under warranty. Came back in less than six months. The location and orientation of the connector allows water to fill and it gets destroyed quickly. My solution was disconnecting that wire from both ends of the connector and hard wiring them together. I haven’t had a problem for the two years since I did that.
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
Case SV280B (A53317)
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
UNUSED FUTURE HYD MINI THUMB CLIP (A57193)
UNUSED FUTURE HYD...
UNUSED FUTURE 14' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 14'...
