2020 Siverado HD
/ 2020 Siverado HD #101
There is a rumor out there of a Navistar International sourced 6.6 gas.
A gas engine from a diesel builder? Brings back memories of gas blocks converted to diesels back in the 80s. Just reversed. I am sure it will be well thought out though.
/ 2020 Siverado HD #102
As I understand it, the EcoBoost is a gas engine that is built like a diesel to handle high boost pressures, perhaps they are following in Ford's footsteps...
Aaron Z
/ 2020 Siverado HD #103
Aaron Z
I hope not! I know of two older ecoboost engines, one just got out of warr. and both turbo's were shot, Ford would NOT help with replacement. That cost him $3,000.00...
The other was burning oil like crazy with only 180,000 on it...
SR
/ 2020 Siverado HD #104
Aaron Z
I agree. I would hope the tech and engineers are more advanced now than back then.
/ 2020 Siverado HD #105
Eco boost engines are fairly new. Not 1980s stuff.
/ 2020 Siverado HD #108
It is a stoked 6.2L with a Cast iron block . GM was probably expecting Tier V and Tier IV emissions which would make the diesel impractical and expensive in “small “ application light and medium duty applications .
That engine would make approx 110-140HP at 1800rpm. This engine and scaled down versions would fit into many current small diesel Agricultural, Marine, standby applications and industrial duty .
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2001 FORD F-150 (INOPERABLE) (A60736)
2001 FORD F-150...
2014 CATERPILLAR CB34B XW DOUBLE DRUM ROLLER (A62129)
2014 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
