2020 Siverado HD
/ 2020 Siverado HD #101
There is a rumor out there of a Navistar International sourced 6.6 gas.
A gas engine from a diesel builder? Brings back memories of gas blocks converted to diesels back in the 80s. Just reversed. I am sure it will be well thought out though.
/ 2020 Siverado HD #102
As I understand it, the EcoBoost is a gas engine that is built like a diesel to handle high boost pressures, perhaps they are following in Ford's footsteps...
Aaron Z
/ 2020 Siverado HD #103
Aaron Z
I hope not! I know of two older ecoboost engines, one just got out of warr. and both turbo's were shot, Ford would NOT help with replacement. That cost him $3,000.00...
The other was burning oil like crazy with only 180,000 on it...
SR
/ 2020 Siverado HD #104
Aaron Z
I agree. I would hope the tech and engineers are more advanced now than back then.
/ 2020 Siverado HD #105
Eco boost engines are fairly new. Not 1980s stuff.
/ 2020 Siverado HD #108
It is a stoked 6.2L with a Cast iron block . GM was probably expecting Tier V and Tier IV emissions which would make the diesel impractical and expensive in “small “ application light and medium duty applications .
That engine would make approx 110-140HP at 1800rpm. This engine and scaled down versions would fit into many current small diesel Agricultural, Marine, standby applications and industrial duty .
2018 International WorkStar 7500 T/A Dump Truck (A66736)
2018 International...
Sullair 375 CFM Mobile Air Compressor (A68134)
Sullair 375 CFM...
1994 MACK CH613 FUEL AND LUBE TRUCK (A67714)
1994 MACK CH613...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
8ft Fork Extensions (A66734)
8ft Fork...
