2020 PTO SEAL
/ 2020 PTO SEAL #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
Is it possible to replace the PTO shaft seal on a YM2020 without pulling the entire cluster out of the tractor? If so, How?
Kicking myself for not replacing it when I replaced the rear axle seals last winter:mad: :mad: :mad: :mad:
/ 2020 PTO SEAL #2
Next time you are down this way stop by . I'll kick it for you for not doing it also:D
/ 2020 PTO SEAL
I replaced both rear axle seals but didn't replace the PTO seal.
/ 2020 PTO SEAL
Come on Guys,
I know someone has replaced one or has a book that tells how to do it:rolleyes: :rolleyes: :rolleyes:
/ 2020 PTO SEAL #6
wish I could help.:( Why not buy the seal from Tom ( he can't be far from you ) & ask some of the guys there if they have a diagram ?
/ 2020 PTO SEAL #7
Can't help you on the PTO seals, but how hard was it to change the rear axle seals? My right rear on my 2210 has developed a slight leak. Also, where did you get the seals and did you change the bearings also?
/ 2020 PTO SEAL
Not a real hard job. Had to pull the PTO cluster in order to unkey the axles and pull them out, then had to pull the top 3PH off in order to get the linkage to hook up when reinstalling the PTO cluster.
Once you get the cluster out it's very easy to pull the axles and replace the seals. Just be sure while you're in it this far to replace both axle seals even though only one may be leaking. Didn't replace bearings, no need to all were very smooth.
Got the seals at Fredricks since I live about 30 miles from them. The seals were less than $20 each. Replacing the PTO seal at the time didn't even cross my mind, wish it had!!!!!
/ 2020 PTO SEAL #9
It looks like you should be able to remove the snap ring & pry out the seal.
/ 2020 PTO SEAL
Thanks Len,
That's what I was looking for, an idea it could be done before I tried it.
Baby Goat Decorative Statue (A66738)
Baby Goat...
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
2020 CATERPILLAR 320 GC EXCAVATOR (A65056)
2020 CATERPILLAR...
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
235/75R17.5 Tire and Wheel (A68134)
235/75R17.5 Tire...
TIRE RACK WITH TIRES (A67714)
TIRE RACK WITH...
