2020 GMC Sierra HD
/ 2020 GMC Sierra HD #21
Here’s my step tailgate.
Works every time.
/ 2020 GMC Sierra HD #22
Here痴 my step tailgate.
Works every time.
My truck is like yours too (no step). I do like the bumper corner step as it is simple, cheap, and out of the way. I would assume that the new GMC multi-gate will never be available on a W/T anyways...
/ 2020 GMC Sierra HD #23
What if you needed to load half a tractor and then dump it off and bounce across the tailgate? Most pickups are already luxury vehicles and will never see a days work ( and the owners probably don’t either ) but this is a really pitiful excuse for something that’s supposed to haul things.
/ 2020 GMC Sierra HD #24
You'll scratch the plastic. Among other things....
/ 2020 GMC Sierra HD #25
That’s probably 3,000 pounds. I’m leaning more towards ripping the tailgate off and causing significant damage to the bed.
/ 2020 GMC Sierra HD #26
Nobody has any business putting that kind of weight in a pickup, anyways. Most people who haul what you do aren't using pickups anyways, as they aren't the proper tool for the job.
/ 2020 GMC Sierra HD #27
I don’t disagree I need a heavier duty duty truck but my dually was perfectly adequate for that load.
/ 2020 GMC Sierra HD #28
Few well placed blows from a sledge straightens out my tailgate.
/ 2020 GMC Sierra HD #29
Pulling something on flat ground on wheels isn稚 even a very impressive feat. If you have the air brakes unlocked you could pull a Fedex trailer on a dolly with a Prius. I don稚 guess the brand of trailer makes any difference but those trailers are frequently on dollies. I致e pushed several thousand pounds on rollers by myself by hand. This one takes some leverage advantage because I can稚 do it by myself straight up but I can move my 12,000 pound forklift with no engine powered tools. I don稚 know how much rolling resistance a loaded semi would have but I壇 bet you could easily pull 2 or 3 on flat and hard ground and all brakes open with a pickup.
In real life I've seen a pickup drag a dead tractor trailer out, no doubt they released the air brakes though and didn't go very far with it.
I will bet that you have pushed more than several thousand pounds... how often have you had to move a dead pickup and simply opened the door and moved it, pushing against the door frame.
There is a bunch of videos out there. The def fluid fill is now next to the fuel fill and the tank doesn't limit ground clearance anymore. They have the new tailgate and the dash view that sees behind the item your towing.
Wow - Watch the 22 GMC Sierra Heavy Duty Pull 225, Pounds! Here's Everything You Need To Know - YouTube
It's pretty bad when the video commercial is interrupted by a commercial. :D
/ 2020 GMC Sierra HD #30
I remember when truck commercials were honest, common sense commercials, focusing on the simple functionality of the truck. There was no shuttle pulling, ship pulling ridiculousness. I guess marketing firms feel as trucks get more fancy, they need to jazz up the commercials. Under all that tech and pretty chrome still lies the worlds simplest vehicle-a pickup truck. Maybe I am old fashioned, but give me a stick shift, rubber floors, a good radio and heat and ac. A 15-20k tow capacity is good for me with a good payload. Those trucks just aren’t made anymore.
/ 2020 GMC Sierra HD #31
With all due respect, tow and payload capacities have improved vastly over the years. Aside from the specs, look at the difference in iron in the frame of a 2019 Sierra 1500 vs that same truck 30 years ago. It's heavier than even an '87 ton truck. Breaking frames used to be business as usual, not from overloading but from pounding down the gravel roads we work on at faster miles per hour.
/ 2020 GMC Sierra HD #32
Go to the city mall parking lot. Look how many pickups are there that don't even have a rock chip. Or how many have some form of stupid bed cover. And look at how many are HD diesels.
That's the market commercials are targeting. Real people, not actors.
/ 2020 GMC Sierra HD #33
Maybe I am old fashioned, but give me a stick shift, rubber floors, a good radio and heat and ac. A 15-20k tow capacity is good for me with a good payload. Those trucks just aren稚 made anymore.
You could buy one in "18" but the stick shift is now gone for "19", you can still get the rest though.
Everyone says you can't buy a new work truck, but you can if you really want to, I did a few months ago...
SR
/ 2020 GMC Sierra HD #34
The manufacturers have to target one type of people.....the ones that buy. Normally I buy the option-less ones that sit on the lot waiting for a contractor or me to buy. I'm content with what I have and when it gets beat up a bit, it's not the end of the world.
/ 2020 GMC Sierra HD #35
Yep. I actually appreciate the mall cruisers. They provide used trucks with 100K miles in perfect condition for 30-40% of new cost. :)
/ 2020 GMC Sierra HD #37
/ 2020 GMC Sierra HD #38
Why bother with a diesel truck and the cost of the diesel option when diesel fuel costing more than gasoline ?
Because I'd had to pull really heavy loads with a gas-engine 1 ton. Torque moves big loads and 900 ft lbs beats 500 ft lbs every time. So does 12-13 mpg compared to 6-7. Been there, done that.
/ 2020 GMC Sierra HD #39
You are out there on the road 5 days a week hauling 20,000lbs 500 miles a day.
Btw your diesel numbers are high and the gas numbers are low .
/ 2020 GMC Sierra HD #40
I don't think my 39 foot RV or my 16-foot dump trailer would be happy behind a gasser.
The cost of fuel varies around the country. By me, diesel is higher in the winter due to the home heating oil demands but typically less than gasoline in the summer.
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2022 EZ-GO ELITE...
2020 CASE TV450B SKID STEER (A65053)
2020 CASE TV450B...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
