two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,744
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
What if you needed to load half a tractor and then dump it off and bounce across the tailgate? Most pickups are already luxury vehicles and will never see a days work ( and the owners probably don’t either ) but this is a really pitiful excuse for something that’s supposed to haul things.
You'll scratch the plastic. Among other things....
Few well placed blows from a sledge straightens out my tailgate.That’s probably 3,000 pounds. I’m leaning more towards ripping the tailgate off and causing significant damage to the bed.
In real life I've seen a pickup drag a dead tractor trailer out, no doubt they released the air brakes though and didn't go very far with it.Pulling something on flat ground on wheels isn稚 even a very impressive feat. If you have the air brakes unlocked you could pull a Fedex trailer on a dolly with a Prius. I don稚 guess the brand of trailer makes any difference but those trailers are frequently on dollies. I致e pushed several thousand pounds on rollers by myself by hand. This one takes some leverage advantage because I can稚 do it by myself straight up but I can move my 12,000 pound forklift with no engine powered tools. I don稚 know how much rolling resistance a loaded semi would have but I壇 bet you could easily pull 2 or 3 on flat and hard ground and all brakes open with a pickup.
It's pretty bad when the video commercial is interrupted by a commercial.There is a bunch of videos out there. The def fluid fill is now next to the fuel fill and the tank doesn't limit ground clearance anymore. They have the new tailgate and the dash view that sees behind the item your towing.
Wow - Watch the 22 GMC Sierra Heavy Duty Pull 225, Pounds! Here's Everything You Need To Know - YouTube
You could buy one in "18" but the stick shift is now gone for "19", you can still get the rest though.Maybe I am old fashioned, but give me a stick shift, rubber floors, a good radio and heat and ac. A 15-20k tow capacity is good for me with a good payload. Those trucks just aren稚 made anymore.
The manufacturers have to target one type of people.....the ones that buy. Normally I buy the option-less ones that sit on the lot waiting for a contractor or me to buy. I'm content with what I have and when it gets beat up a bit, it's not the end of the world.
Yep. I actually appreciate the mall cruisers. They provide used trucks with 100K miles in perfect condition for 30-40% of new cost.![]()
Why bother with a diesel truck and the cost of the diesel option when diesel fuel costing more than gasoline ?There is a bunch of videos out there. The def fluid fill is now next to the fuel fill and the tank doesn't limit ground clearance anymore. They have the new tailgate and the dash view that sees behind the item your towing.
You are out there on the road 5 days a week hauling 20,000lbs 500 miles a day.Because I'd had to pull really heavy loads with a gas-engine 1 ton. Torque moves big loads and 900 ft lbs beats 500 ft lbs every time. So does 12-13 mpg compared to 6-7. Been there, done that.
