- Joined
- Sep 6, 2011
- Messages
- 14,195
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
No... I'm just here for Fuddy's stories.Same is true for Tractor owners or anything else.
I've got you beat, with 21 years of RAM ownership here, actually closer to 40 years of combined Dodge ownership, and very few problems ever.
But Code54's issue really isn't that a part failed or was defective... that happens on all brands. His issue is their response, leaving him with no repair option that won't void warranty, etc.
Me? I'd say "screw the warranty", and just get the damn thing fixed with the same part used on the 3500. What use is the warranty, on a vehicle you can't drive?Having said that, I'm still cheap enough that I'd still be arguing to get each subsequent repair covered under warranty.
Like any other forums, you have to be able to separate the wheat from the chaff. Yeah, there's of crabbing and whining over either minor issues, of how the dealer's jerking them around, or how it's a POS and you'll never buy that brand again. Often as not key facts are being left out that might point blame at the poster.“stay off the truck forums, they will just upset you. They are made up mostly by people with complaints. The happy owners usually aren’t on them”.
I always ate my lunch in my truck at work. Didn't want to listen to people in the lunchroom talking about how screwed up the boss/another employee or the or the company was. Negative thinkers do like to drag to into their pit.One of my best friends is a very experienced Ford diesel mechanic. Works at local Ford dealer. He says he is as much a “therapist” as he is a diesel technician.
One thing he told me that really stuck with me was this:
I’m not saying there isn’t problems, but owners with problems like to use the internet forums to complain.
The OP’s complaint is understandable, but I’ve also read hundreds of BS complaints, too.
Again, I'm going on memory here and haven't Googled the issue to find out if I'm correct, but let's say it is just the motor, and it also fits other years.Me? I'd say "screw the warranty", and just get the damn thing fixed with the same part used on the 3500. What use is the warranty, on a vehicle you can't drive?Having said that, I'm still cheap enough that I'd still be arguing to get each subsequent repair covered under warranty.
I would do same. How will they know? When the correct part arrives, just remove the 3500 part and put the defective part back in. It’s just a frickin sensor or module.
People gotta learn to adapt.
NBC's "Cost of Denial" series.Escalating can work wonders at times.
Someone went to a TV consumer reporter saying they have $500 monthly payments on a car the manufacture says not to drive.
Within a week her car was fixed…
The squeaky wheel gets the grease?
Where I see Code54's issue is at is if his truck is declared unsafe in writing. If he does something to fix it himself or drives it and has an accident his insurance has an out. Legal issues?
The next two days I spent trying to get the alloy wheel off the hub. I couldn't believe it - it was well less than a year and it was glued. 20# copper sledge, pry bars, a scissor jack. Nope.
Absolutely true.Fairly common problem with some of the alloy wheels - galvanic action causes them to seize to the iron hub. Used to happen with my F150. Once I got the wheels off I put a thin layer of antiseize on the mating surface. That solved the problem.
I can’t remember how I did it without going to low or breaking something but I suddenly lowered a vehicle on a floor jack to pop a wheel loose.
The recall is documented. That could change things.Agree 100%
Then we are all screwed because every redneck, motorhead, trucker & farmer has wrenched on his trucks & equipment.
I could rotate my own tires and if I don’t torque the lug nuts correctly, or I change my own brake pads and some lawyer could prove that caused the accident and insurance wouldn’t cover it either.
If what you mean is the dealer says “park your Ram and DO NOT drive it”, then that should be obeyed.
On which pedal?I bought a new GM Silverado one year, not that long ago.
Couple years later, I went right through a busy intersection red light, with my foot to the floor, without hardly slowing. How I was able to avoid the oncoming green light traffic was a miracle.
GM was using junk Chinese common steel on brake lines.
No engineering for rust belt sales.
No recall. Nothing.
They quietly switched to rust resistant materials in subsequent years. Swept under the carpet.
At least The potential Ram brake issue is being acknowledged and a recall issued.
