2018 5075e Accelerator Pedal Bounce
/ 2018 5075e Accelerator Pedal Bounce #1
mtncur
Grand Rivers, Kentucky
John Deere 5083e, Kubota L3240
On my new 5075e I cannot keep the engine RPMs steady using the foot throttle. The hand throttle is fine, but using the foot throttle, I am getting a ton of "bounce". Feels like maybe not enough friction, or needs a heavier spring or something. Anyone know if there is an adjustment or heavier spring or something for this? I use the foot throttle a lot for loader work, setting out hay, etc. so this is a bit of a pain. On my 5083e, this is not an issue, the foot throttle is fine.
/ 2018 5075e Accelerator Pedal Bounce #2
The throttle is electronic on the newer tractor so you are only moving a sensor versus moving throttle linkage on the older tractor. I don't think deere is offering any parts to stiffen that up. May need to fabricate something to get the feel you want.
/ 2018 5075e Accelerator Pedal Bounce #3
New John Deere 575E improvements! - YouTube
/ 2018 5075e Accelerator Pedal Bounce #4
mtncur - you are not alone there. My 2009 Kubota M6040 has mechanical linkage on the foot throttle. I'm TOTALLY unable to maintain any sense of stability if I use the foot throttle out and about on my land. As a matter of fact - the VERY FEW times I've tried the foot throttle - I fear for damage to the drive line/train - there is so much 'bounce" - with my foot, then to the tractor.
JMHO - the foot throttle is only intended to be used when operating on smooth roads or paved surfaces.
Agreed, and I can't keep even keep it smooth on paved surfaces.
/ 2018 5075e Accelerator Pedal Bounce #6
Would it help to adjust the seat height so your heel is supported or leg position is better? Maybe install a block for your heel to sit on (2 sided tape)?
/ 2018 5075e Accelerator Pedal Bounce #7
Ok - well, on my driveway or the paved county road I CAN maintain an even speed with the foot throttle. The main "joint" on the mechanical linkage for the foot throttle has a tension adjustment. A nut/bolt/spring/couple washers - with the linkage levers in this mix. I never use the foot throttle so I've never fiddled with this tension adjustment.
The hand throttle works fine, for me, and with my luck - if I fiddle - it might jam. And jam wide open. There are those times when traveling around my property does involve a lot of mud slinging.
/ 2018 5075e Accelerator Pedal Bounce #8
Weird, why they'd design it like that? Why wouldn't they let you adjust the resistance at the pedal pivot point like they do with 3 point levers, or the cruise control level on my garden tractor? (Maybe because it needs TO operate as a "dead's man's" throttle?)
I use foot pedal for 90% of what I'm doing, unless I'm trying to maintain 540 pto. Having to use hand throttle would be a pain. Growing up, I thought John Deere having foot throttles made them superior to those red tractors.
In fact, other than running 540 pto, the only time I have to use the hand throttle is when I'm ON THE ROAD (or brake steering).
That is, when going full speed on the road and I hit a bump, seat bounces, so leg/foot bounces, so tractor speed hiccups, which causes seat to bounce again, leg/foot bounces again, rinse and repeat... or push hand throttle to max.
/ 2018 5075e Accelerator Pedal Bounce #9
No problem with hand throttle with the hydro tranny.. ;)
2018 FORD F-150 (A67714)
2018 FORD F-150...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
136" BULLDOZER ROOT RAKE (A65056)
136" BULLDOZER...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
2008 FORD E-350 CARGO VAN (A66091)
2008 FORD E-350...
