2017 Workmaster 60
   / 2017 Workmaster 60 #11
The loaders to my knowledge are the same and should spec the same. Don't know why the specs would differ.
   / 2017 Workmaster 60 #12
   / 2017 Workmaster 60 #13
The specs on the Farmalls do not match with their own literature. On the front page they state max lift of 1,742 to 3,142 pounds with heights of 102 to 125 inches at 800 mm from the pivot point. If you drill into the specific loaders they list the L545 at 1,250# max and the L555 at 1,782# max at the pins. The 621TL on the New Holland is rated at 3,550 pounds at the pins at 119" and 2200# at max height at 800 mm. Would not make sense to me that they would have different loaders on the exact same tractors painted different colors. Perhaps they do.
   / 2017 Workmaster 60 #14
I think that literature your referring to may also apply to the other 2 loaders which only fit the “c” farmalls
   / 2017 Workmaster 60 #15
Picture of the new Workmaster series. Looks just like the T4 powerstar. I'm wondering if they are renaming the powerstar and adding some smaller HP models in that frame.:scratchchin:
My dealer said he has limited info on it, but he expects to see it next month at a Ag show and he knows they already have a few pre ordered.
   / 2017 Workmaster 60 #16
That looks significantly bigger than the current workmasters, but it looks like you’ll get your radial r1 option BMan :drink:
   / 2017 Workmaster 60 #17
If it is a lower HP version of the T4 Powerstar I assume the tractor would be made in Turkey? To me it would be easier to slip in a lower HP engine in the T4 versus redesigning the current Workmaster to add 12x12 hydraulic shuttle and cab. If that is the case then the tractor could still be made in India. The only reason I traded my Workmaster 50 for the T4.75 was to get a cab. Soon as I do that New Holland puts in a cab on the Workmaster. Boy is my timing off.
   / 2017 Workmaster 60 #18
Nowhere, Yeah I see that :D. It will be according to how rich that new cab version is for me to upgrade to those radial R1's though ;) I wouldn't trade for another ROPS tractor, I do like my WM 60, but working all day in 100* heat could be more enjoyable with a cab if CNH isn't wanting T4 prices for this thing.
   / 2017 Workmaster 60 #19
Here is a link to download the new Case Farmall A 55, 65, 75 brochure that has all the info on the new tractor. The Workmaster will be the same, can't find a brochure for it.
Pretty dang nice, but I don't see a buddy seat in the cab pictures, that would probably cross it off for me. They mention keeping it very affordable, curious what that would be though.
https://www.google.com/url?sa=t&sou...WMAZ6BAgDEAE&usg=AOvVaw1oX0NzCND4fL2G0DWez6Lw
   / 2017 Workmaster 60 #20
I noticed that it has a stated 81.8" wheel base in 4x4. That is longer than the current Workmaster 50/60/70 series which is 77.5" and shorter than the current T4 which is listed as 82.8". I bet it is the same chassis as the T4 series and they put in the current 50/60/70 engine, 12 speed shuttle option, and cab. Makes sense to me. Guess they decided to leave out the buddy seat to save money along with the manual spring seat. They are trying to hit a 35K-40K price point. Probably made in Turkey.
2008 Toyota Camry LE Sedan (A55853)
2008 Toyota Camry...
23222 (A50323)
23222 (A50323)
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
