2016 Truck Crash Test
   / 2016 Truck Crash Test #11
Did they even test the 2016 Regular Cab or SuperCrew F150?
Good question ! why four GM models and only one Ford
   / 2016 Truck Crash Test #12
To me it looks like the Ford cab separated from the frame and absorbed some of the shock that way. You can clearly see it getting pushed well into the box.
The RAM is pretty alarming. That's a nasty failure.
   / 2016 Truck Crash Test #13
The Ford SuperCrew scored 'Good' last year and was not changed for this year. The SuperCab was changed to add an additional support bar (that was on the SuperCrew last year). I don't think that the regular cab Ford was updated, so no need to test.
   / 2016 Truck Crash Test #14
Hmmmmmm I didn't say they failed , I asked "did they fail" and stated it was poorly written report. Seems reading is a common failure. Quite frankly the Chev and the GMC models are the same truck (at least frame wise)... so actually they could of just as easily tested two GM models and added in a second Ford model. But I guess it is easy to see why the test was posted. (here at TBN and there)
Once again, you failed at reading the article. See below.
Per the article, the Supercrew was tested last year and did well (it received "Good" scores in all categories): Ford F-15 crew cab aces IIHS tests
The SuperCab was also tested last year, but it didn't do as well (results below):
attachment.php
The IIHS says that "The ratings of one vehicle often apply to other models if they are built on the same platform. In addition, a test of a vehicle from one model year may apply to earlier or later model years if the vehicle hasn't been significantly redesigned"
As such, there was no need to include the SuperCrew unless it was "significantly redesigned"
My guess would be that last year, only the F150 was tested (the IIHS wanted to see how the new aluminum body did) and Ford was unhappy with the results for the SuperCab, so they reworked it and had it included in the tests for this year, when the IIHS tested the other manufacturers 1/2 ton extended/crew cab pickups.
As for other cab variants, it looks like the 1/2 ton tests were all extended/crew cab pickups, they don't appear to list any 1/2 ton regular cab pickups as being IIHS Certified.
Aaron Z
   / 2016 Truck Crash Test #15
The important thing is it states what you want to hear.... ..ignore anything else obviously missed (GM models did not change in past two years why in report. Small overlap test not even listed before this year so why not include all models for all makes (as can be seen by digging deeper in report.........)
   / 2016 Truck Crash Test #16
The GM and Ram were in the list because they had not been tested before. I'm pretty sure that test was new last year and the F150 was the only one tested then.
Why is that so hard to understand? Before bashing, why not read and look for all the facts. The facts are that the F150 was the only truck tested to receive a 'Good' rating. Period. It sucks to want to bash something, but you can't find any real reason to bash so you have to accuse others of leaving out facts, doesn't it?
   / 2016 Truck Crash Test #17
What do you think I want to hear?
Do I like Ford sure.
Do I own one?
Nope, in fact the family (between us, parents and siblings) we have a GMC (Yukon XL), Chevys (Suburban and Equinox) Volvos (940, V90, V70), a Dodge (1500 pickup), a Chrysler (Town and Country), a couple of Hyundais (a Santa Fe and a Sonata), and several VWs (Jetta/Golf).
Why? They haven't had one that fits my needs when I was purchasing one.
What I want is accuracy. If the test says that Chevrolet is the best, why make excuses for the others or imply that there were others that were included and failed.
Why should the IIHS test the same number of trucks from each manufacturer?
Why should they retest a truck that is pretty much un-changed from last year (the SuperCab)?
As for why they didnt test a Regular cab, I ran across this article: IIHS: 215 Ford F-15 Crash Tests Reveal Disparate Results Between Body Styles – News – Car and Driver | Car and Driver Blog which says that the IIHS normally only tests the most popular variant of a model.
Another good read is: Equipment disparity on Ford F-150 prompts new crash test which suggests that Ford was trying to game the IIHS test with the CrewCab in that it has extra bracing not found on the Regular cab or the SuperCrew (which is why the SuperCrew was tested last year and that is probably the change that prompted the retest of the SuperCrew).
In fact, Automonews.com said that testing the SuperCab was "an unprecedented follow-up crash test of a lower-volume pickup model by the Insurance Institute for Highway Safety"
They went on to say:
According to IIHS, the test was done specifically because Automotive News alerted it to extra safety equipment that Ford installed on the top-selling SuperCrew model -- the single model that IIHS normally tests -- but not on its Regular Cab or SuperCab F-150s. Other pickup makers will be subject to new tests on their lower-volume models starting next year, an IIHS spokesman said.
Further on the subject:
http://news.pickuptrucks.com/2015/08/who-wins-when-iihs-crash-tests-more-vehicles.html said:
A lot has been said about the results of the Insurance Institute for Highway Safety's small overlap front crash-testing of the 2015 Ford F-150 SuperCrew and SuperCab. IIHS decided to test different cab configurations after it was brought to its attention that front wheel blocker bars are included on the higher-volume four-door crew-cab Ford but are not included on the smaller extended-cab or regular-cab versions.
As a result, the 2015 SuperCrew got the IIHS Top Safety Pick designation while the extended-cab version did not because it achieved a marginal rating on a scale of good, acceptable, marginal and poor on the small overlap front crash test. To get the Top Safety Pick award, a vehicle must get a good or acceptable rating in that test and a good in the other four tests. It should be noted that the SuperCab did achieve a rating of good in the other tests.
When media outlets found out about the wheel-well blocker issue, it didn't take long for many journalists to cry "foul" and accuse Ford of trying to "game the system" by taking advantage of the fact that the IIHS had never tested all of the F-150's cab configurations. Until now IIHS has only tested (it purchases each of its test vehicles from private dealerships) the volume leaders in a vehicle's lineup, which, in the pickup segment nowadays, is the crew-cab model. (We should note that IIHS is likely to be more comprehensive in its vehicle testing in the future to detect differences like those found in the F-150.)
Common sense dictates that if a vehicle has a slightly different size, shape, mass and structural configuration that it might get slightly or significantly different crush and deflection results when involved in an offset collision (in this case, offset on the driver's side by 25 percent of the total width of the pickup). And that's exactly what the IIHS found when it tested the F-150's less popular extended-cab version. Extended cabs are estimated to be 20 to 25 percent of total F-150 sales; regular cabs account for less than 5 percent.
The question here is whether Ford is at fault for treating each of its cab configurations differently (all three cab versions did receive a five-star rating from the National Highway Traffic Safety Administration, the max for its tests), including the "right amount" of structural support necessary for each cab, or if all vehicles with the same name should meet similar crash-test requirements. The issue is tricky. Was Ford responsible for IIHS not including other cab versions to see if they would test differently on the small overlap front test? The answer to both questions is probably not. And remember the other truckmakers have not had different cab configurations tested by IIHS either; they too have only had their high-volume players tested.
For the sake of argument, if Ford had only included those deflection bars (highlighted in yellow and red in the photo below) at the front and rear of the wheel well on the units tested by the IIHS, then accusing Ford of making a vehicle just for this test might make some sense. But as near as we can tell, that's not what happened here. Instead, it sounds like we have a test that's going to be conducted on all pickup truck cab configurations (or at least crew and extended cabs) from now on. That will have the eventual impact of making truck owners safer if, heaven forbid, they find themselves in an accident.
attachment.php
Shame on Ford for trying to game the system and shame on the other brands for not getting their trucks ready for this.
This test (small frontal overlap) has been in the works since 2012. Chevrolet/GMC and Ram have all had a refresh since then. Why didn't they incorporate something like this when they did their refresh? Its not like the test is a secret or that its not testing that they don't do themselves (or if they don't do it, they should be doing it).
Aaron Z
Finally, a sensible answer.
Chris
   / 2016 Truck Crash Test #19
Hey, thanks for clarifying, guys. I have the 2016 F150 Super Crew, and it was not until I went through all of this discussion that I realized that it was the 2015 that was tested.
   / 2016 Truck Crash Test #20
And I have the 2015 F150 SuperCrew so guess that's as good as it gets.:laughing:
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A51222)
2020 INTERNATIONAL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
