2015 Ford SuperDuty Specs
   / 2015 Ford SuperDuty Specs #2
   / 2015 Ford SuperDuty Specs #3
'best in class fuel economy when run by Ford in tests'......ok, what is it?
as for the torque wars, it is so far gone it doesn't even matter anymore. in fact, the others are downsizing their diesels to get higher mileage! Ford in fact, is behind - hence their new "Lion" program.
I don't consider this announcement being "on top" anymore. Otherwise Cummins would just drop a 6C engine in.
   / 2015 Ford SuperDuty Specs #4
Yep, I agree. Ford, Chevy, whatever. You can't beat a Cummins. From tractors to ships to smaller locomotives. .. even pulling trucks. They're hard to beat. Give me less hp and a few more mpg...
   / 2015 Ford SuperDuty Specs #5
Those are impressive numbers for sure! I still would be nervous about having that kind of weight behind a p/u though regardless of brand. Are they going to be putting air brakes on p/u's next? Getting a load moving is hardly the task it used to be. Getting it stopped with all the "EXPERT" drivers on the road really concerns me the older I get. Who's going to be the first one on here to step up and buy the first 100k pickup? lol
   / 2015 Ford SuperDuty Specs #6
The Ford is impressive, it has 4.30 axle gears which is what a truck needs for towing. Wonder what the next Ram Cummins will crank the power up to?
I've had two F-450 pickups, an '08 and currently a '12. The '15 F-450 will be a lot like my '08 because it will have the 19.5" commercial grade tires and the heavy Dana 110 rear axle. The F-450 also has the wide-track front axle which adds to stability but allows the tires to cut sharply for a tight turning radius. Both of my trucks have been premier towing machines and I can only imagine how the '15 will handle a load with the extra horses under the hood.
   / 2015 Ford SuperDuty Specs #8
so Cummins now make trucks? i always thought they stuck to engines?
the amount brand bashing on this forum always astounds me
   / 2015 Ford SuperDuty Specs #9
Does the 450 have a beefier frame than the f350? I would imagine they would come in different lengths also?
   / 2015 Ford SuperDuty Specs #10
That's definitely some nice numbers.
Yes. Yes.
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
Safety Cones and Barrels  (A52384)
Safety Cones and...
2018 Ford Fusion Sedan (A51694)
2018 Ford Fusion...
2019 Autocar ACX Xpeditor T/A EZ Pack Front Loader Garbage Truck (A51692)
2019 Autocar ACX...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53473)
Chevrolet C8500...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
