2014 toolcat 5600
/ 2014 toolcat 5600 #1
Smuth66
2014 5600 Toolcat
Problem 50-56 code machine starts and idles, bucket goes up and down, dump bed works, does not go forward or reverse, throttle lever no response, no blown fuses or shorts in fuse boxes, can wires show continuity from display controller to drive controller. What I'm missing?
/ 2014 toolcat 5600 #2
Some threads:
https://www.justanswer.com/construc...3s-bobcat-5600-toolcat-50-56-code-starts.html
https://www.justanswer.com/heavy-equipment/21avu-toolcat-error-50-56-moving.html
Taking apart 5600 to fix 50-56 error code
Toolcat dead once again 50-56
/ 2014 toolcat 5600 #3
All 4 of the AWS magnetic solenoids receive 12v supply from the 4510 wire. Solenoids should have approximately 7.5 Ohms resistance. Verify each solenoid with Ohm meter.
The suspected solenoid is reading 0.6 ohms while other 3 read 6.8-7.6 ohms.
In the 3rd thread, birddog0304 did replace the solenoid that was shorted and it fixed his TC.
/ 2014 toolcat 5600
Ok thanks for info. Since i'm not the original person to work on this machine and it set at the dealer for two months to be told it needed a new harness with material/labor apx 4k! The machine was brought to me with the code and no blown fuses you could tell they did not look because screws were rusted shut to look at the back of the fuse box. No blown fuses , the fuse box under driving seat had two wires burnt which one marked with computer symbol . solder and heat shrink no code back up and running. SHAME ON YOU DEALER!
GREEN LEE KNOCK OUT SET (A63745)
GREEN LEE KNOCK...
2007 DRAGON 130BBL VACUMM TRAILER (A63569)
2007 DRAGON 130BBL...
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2015 WESTERN STAR  4700 SF DAY CAB (A63569)
2015 WESTERN STAR...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
