2014 T4.75 Low oil pressure light (inherited tractor)
   / 2014 T4.75 Low oil pressure light (inherited tractor) #1
Ethan0718
New Holland t4.75
First time poster here. I recently inherited this tractor from my uncle and have been using it recently to tend to his cows. Last week the low oil pressure light came on and I immediately cut the tractor off. I’m kind of lost trying to fix it. Firstly I will be changing oil and filter this weekend as I’m unsure of previous maintenance done. If this doesn’t fix it I’ve been reading on here and other places to screw a gauge into the block to check pressure but don’t know where I would screw it into. Does anyone know where the pressure sensor should be? Any insight or help would be greatly appreciated!
   / 2014 T4.75 Low oil pressure light (inherited tractor) #2
Welcome to TBN!
Here is the diagram of the senders. It is below the oil filter, #2
Awesome! This will be very helpful thank you.
   / 2014 T4.75 Low oil pressure light (inherited tractor) #4
Put an analog gage on it. Sensors aka: idiot lights are just that, idiots.
So today I changed the oil and filter and jumped on it to see the following code. Any idea what this means?
   / 2014 T4.75 Low oil pressure light (inherited tractor) #6
ECU Not Detected on CAN bus.
Read this post:
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
2008 New Holland B110 MFWD Loader Backhoe (A53472)
2008 New Holland...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
