2014 T4.75 Low oil pressure light (inherited tractor)
   / 2014 T4.75 Low oil pressure light (inherited tractor) #1
Ethan0718
New Holland t4.75
First time poster here. I recently inherited this tractor from my uncle and have been using it recently to tend to his cows. Last week the low oil pressure light came on and I immediately cut the tractor off. I’m kind of lost trying to fix it. Firstly I will be changing oil and filter this weekend as I’m unsure of previous maintenance done. If this doesn’t fix it I’ve been reading on here and other places to screw a gauge into the block to check pressure but don’t know where I would screw it into. Does anyone know where the pressure sensor should be? Any insight or help would be greatly appreciated!
   / 2014 T4.75 Low oil pressure light (inherited tractor) #2
Welcome to TBN!
Here is the diagram of the senders. It is below the oil filter, #2
Awesome! This will be very helpful thank you.
   / 2014 T4.75 Low oil pressure light (inherited tractor) #4
Put an analog gage on it. Sensors aka: idiot lights are just that, idiots.
So today I changed the oil and filter and jumped on it to see the following code. Any idea what this means?
   / 2014 T4.75 Low oil pressure light (inherited tractor) #6
ECU Not Detected on CAN bus.
Read this post:
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
WOODS DHS48N LOT NUMBER 75 (A53084)
WOODS DHS48N LOT...
