2014 New Holland TS6 110 3point bounces with Mower attachment
   / 2014 New Holland TS6 110 3point bounces with Mower attachment #1
Rstevens47
New Holland TS6 110
Hey all, I'm a mechanic for local government and one of my departments has a 2014 New Holland TS6 110 that has a big mower attachment on the rear connected to the 3pt hitch and the issue is that the attachment is starting bounce while driving and shakes the entire cab making it undriveable, while parked the mower will also slowly lower after a few hours, it goes very slow but you can hear it creak. Disconnecting the back mower solves the problem. Anyone have similar issues? I'm new to this piece of equipment.
   / 2014 New Holland TS6 110 3point bounces with Mower attachment #2
For the bouncing, just drive slower.
For the leak down, that’s normal; my MF1540 does that (slow leak down of the 3 pt and creaking)
   / 2014 New Holland TS6 110 3point bounces with Mower attachment #3
For vintage tractors that leak down or need help controlling a 3pt mower, they can buy a stabilizer kit that triangulates the 3pt with chains. It does sound like the OP is describing is a speed problem though.
Mower Deck Height Stabilizer Kit Cat-1
   / 2014 New Holland TS6 110 3point bounces with Mower attachment #4
I'm guessing the tractor is sitting in one spot for a while(days) and the tires are flat spotting. When this happens it takes 30 mins or so of driving to get the flat spots out. Until that happens it will beat you to death. Most non-radial tractor tires will do this. I know mine do.
   / 2014 New Holland TS6 110 3point bounces with Mower attachment #5
It is normal for the mower to bounce a little when the tractor is driven with it in a raised position. Rough terrain and higher speeds will increase the amount of bounce.
2023 Caterpillar 299D3 High Flow XPS Compact Track Loader Skid Steer with CAT GB124 Grader Blade (A52377)
2023 Caterpillar...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
Utility Trailer (A52377)
Utility Trailer...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
