2014 JD85E
/ 2014 JD85E #12
Does John Deere make the mx series mowers or are they made by someone else?
/ 2014 JD85E #13
Made by john deere in mexico.
/ 2014 JD85E #14
Does anyone else make a similar mower like this?
/ 2014 JD85E
Woods makes a hydraulic off set. For the 10 footer it was about 1500 more then the mx 10. Looks a little heavier and cuts a inch bigger brush. For me the mx 10 was a better deal and looks built plenty heavy for my use.
/ 2014 JD85E #16
Thanks for the info. Ill probably go with an 8' if they make it. Still on the fence about getting a flail. I keep talking myself around in circles. lol
/ 2014 JD85E #17
Can you still use a MX8 pull behind with the hydraulic offset? I've purchased the MX8 pull behind rather than the 3 pt considering I have gently rolling hills in some areas of our land.
Finally getting around to posting pics of my tractor. I bought this tractor from Baders & Sons in Tecumseh Mi. By far one of the best experience's with a dealer. I would highly recommend them, My salesmen was Scott Header. I shopped many brands before settling on the deere, almost but a Kubota. Havent had a lot of seat time yet, spent a few hours moving snow this last weekend. Coming from a hydro back ground took a few minutes to get use to the power reverser. I love the interior and layout of the cab, very happy with the speed of the hydraulics. Another plus is just how quite this tractor is, with doors closed you can hear the radio at its lowest setting. Its amazing how smooth the engine is, like riding in a car. It was in the single digits Sunday morning and I had to turn the heat off, it will burn you out. I also picked up MX-10 with hydraulic off set really looking forward to using it. It a beast of a mower.
/ 2014 JD85E
You can only get a hydrulic offset with a semi mount. Not sure if anybody makes a pull behind hydrulic offset.
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
