2014 Chevy/GMC specs
/ 2014 Chevy/GMC specs #61
I don't think a diesel 1/2 ton truck is worth it. Maybe 10 or 20 years ago it would have been. With todays technology a gas motor is hard to beat in that platform. If the diesels did not have to meet these stupid emission regulations things may different.
In the current EPA environment, that's certainly true.
/ 2014 Chevy/GMC specs #62
Ok...You've made your loathing of GM abundantly clear over the last 4+ years and I think everyone is very aware of your position on the matter..Time to let it go..It's worn out it's welcome to be honest.
That being said..What's wrong with the updated 5.3?...Gets the same or better mileage with a relatively simple normally aspirated V8 as opposed to multi turbos on a V6 to accomplish the same thing....A 400+ HP Corvette can easily get mid 20's, however a similar drivetrain in a 5000# truck can't produce the same results at this point...The GM powerplants are fuel efficient on their own, it the brick aerodynamics and sheer weight or the trucks hold them back, same problem that everyone has...With an aluminum frame, 2:73 gears, a sloped front end and no 4wd along with a 500# tow capacity could easily produce mid to high 20'sMPG...No one would buy it as it would be useless.
What innovative drive train were you expecting?...GM sticks with what works...Not what infatuates people..Ergo the 350ci that is still the most popular motor ever built....Improve what works, don't keep throwing things at the wall hoping something will work..That's not innovation.
I didn't buy my truck for MPG anyway...I'll take the average 16mpg with 403HP that I get.
As far as design is concerned I think it maybe a matter of preference, GM in the past was always known for parts interchangeability it got them a huge following in the hot rodding community and I for one am thankful for the fact that many parts could be interchanged, and pushrod over head valve engines are simpler, and being normally aspirated , when the day comes to rebuild it the cost is going to be less.. so if GM can get similar mileage and performance without resorting to 4 valves per cylinder, twin turbos and overhead cams..it's ok with me, and when those vehicles-engines reach 150k miles I might still consider purchasing one, but a twin turboed 4 valve per cylinder engine with those miles that hadn't been rebuilt -not going to happen...
/ 2014 Chevy/GMC specs #63
I fully agree....When I was broke, I bought a variety of GM V8's with at least 100k and ran them to around 140k and sold them for what I paid for them..I would see the ones I sold running around for years after...Don't know many gas turbos that last that long..That might change, I'll keep an open mind.
As a recovering and soon to be again restorer, I certainly appreciated the interchangeability of the GM's...Even putting a SB GM in a Ford was fairly simple.
/ 2014 Chevy/GMC specs #64
Keep in mind that a turbo motor does not make boost all the time. It is basically a naturally aspirated engine til you stick your foot in it.
/ 2014 Chevy/GMC specs #65
While turbos (if not maintained well) may have a limited life span multi-cams and 4 or 5 valve per cylinders engines have been around for decades. There is no proof that they need any more work than the standard 2 valve pushrod design. On top of that high pressure direct gas injection is more of a worry for longevity than an overhead cam. It's use over the last century has been limited to a handful of vehicles. I do think it's time is here thanks to improvements in technology but never the less how long the injectors will last may not be as long as the rest of the engine.
/ 2014 Chevy/GMC specs #66
I think there is a place for a diesel in a 1/2 ton truck. But it means putting one in that is equal in power to the base model V6 engine. Something that's not designed to pull a 14,000k load. A 200 hp diesel would be more than enough and could get a high enough MPG improvement to justify the extra cost.
/ 2014 Chevy/GMC specs #67
With these gas trucks getting close 23-24 MPG I don't think a diesel will do much better. It may get 28 MPG but with the higher initial cost, higher fuel price, and higher maintenance cost it would make the gas truck tough to beat. Usually a gas motor is cheaper to do repair work to also.
/ 2014 Chevy/GMC specs #68
In a pickup, you'd have your foot in it much more than you would in a car...Basic lack of displacement moving 5000# plus any load. The turbo(s) are working to make up the difference..Just physics..I have no dog in this fight..Until a turbo'd motor can carry itself without boosting constantly under any load, I'll stick with base displacement...That may well change someday..But not today. Talking gas, not diesel.
/ 2014 Chevy/GMC specs #69
Volvo cars have been running to 200k or more miles with 4 cylinder turbos since at least the 80s and 5 cylinders turbos since the 90s. Dad had an 1998 S70 that had 210k miles on it and it was just starting to leak at the turbo oil seals when it met up with a telephone pole thanks to some black ice.
Turbos dont worry me much. Dont hypermile all the time (ie: get out and stomp on it from time to time), run Synthetic oil and they will be fine.
Aaron Z
/ 2014 Chevy/GMC specs #70
Aaron Z
I have to say that it is because it's a Volvo IS part of the reason the cars run so long , and of the Volvo's I have seen that needed expensive repairs- the majority were turbo charger related problems... The earlier Volvos didn't have turbos and I know of at least 2 that have run in excess of 350,000 without a major repair
/ 2014 Chevy/GMC specs #71
Glad to see every manufacturer moving up their game with improvements to power and efficiency. Three years ago Ford rocked the industry and now Ram and GM are catching back up. I am interested in seeing the new 6.2 liter and think it might have a torque curve that beats the ecoboost.
This 5.3 is 6% better in MPG but 10% less in peak torque. Nice flat curve though for NA motor.
While MPG are nice I look at total package. I still feel the F150 has this licked. The Ram is close but the payload and real world tow rating due to its suspension limitations are its only draw back.
When I bouught my last new truck in 08 I did not buy what had the best MPG, highest HP, ect. That is for the people who know very little about trucks, I bought what was the best overall package.
Bragging rights are nice for marketing but give me a truck that does everything good.
Chris
/ 2014 Chevy/GMC specs #72
I can shed some light on this subject with real data. I have a SCREW ecoboost with a boost gauge.
On the interstate with level ground, no wind, I am still in a slight vacuum. If I encounter a 10 mph headwind, I am at 0 manifold pressure. Any hill with cruise control will bring boost in.
Towing my 5000 lb trailer pictures at the bottom running 70 mph I am at 5 lbs boost.
Normal starts with a light foot will yield 0 manifold pressure at upshifts. Full throttle starts will hit 15 psi in upper gear upshifts.
All this being said, you are correct. Boost is needed in a smaller displacement motor to move such a large vehicle. Your desire to have a an engine not require boost under any load is confusing to me. Of course that would be possible but you would end up with an engine that creates 500+ HP and 600+ torque and you would loose all the efficiency.
I also don't understand people's fear of boost. I enjoy seeing manifold pressure building while steaming up the hills.
/ 2014 Chevy/GMC specs #73
For comparison, my '95 CTD sits at about 8psi of boost at 72mph on the interstate. This is at about 2k rpm and with side boards on the bed sides. The trucks weighs 6800lbs or so.
/ 2014 Chevy/GMC specs #74
Interesting. I am also at 2000 rpms at 70 with 3:73 rear end.
/ 2014 Chevy/GMC specs #76
I have owned both Ford and Chevy trucks. My 97 F150 4x4 has had quite a few problems, mainly electrical, and needed a new motor at 140k miles (4.6). My other 3 Fords, including 2 6.0 diesels, but for a tps sensor, were flawless. My 2005 Z71 was problematic, bad gauges, leaking windshield and towed poorly, constantly downshifting. My other 3 were flawless, including my 2011 Z71 with 30k miles. The 6 speed auto makes towing much better than the 4 speed in the 05. I like simple truck engines and GM won over Ford. The 4.6 in my 97 is a pain to work on. Otherwise, it could go either way for me. Never owned a Chrysler/Dodge so cannot comnent, but I think the Challenger is the best looking of the 3. Looks the most like its predecessor. Also, the cummins is legendary in power and effeciency. Don't see how anyone can argue that.
I have read claims of the 6.2 GM making 450 hp and 450tq, but that is just claims. 420/430 probably more realistic.
/ 2014 Chevy/GMC specs #77
One of my customers came over last night after dinner to borrow my 7' 3000# lawn roller. He had a 2013 Chevy Crew Cab 4x4 1500. I gave him plenty of crap. Lol...
Anyway his 09 Ram was giving him fits and it needed brakes, tires, and a new tailgate due to backing it into a tree.
He said he took his wifes Buick in for service and got talking to the salesman. Long story short they gave him $19,750 for his truck as is and he got $10,500 in rebates and incentives plus his wife had a big credit on a GM credit card.
Sounds like they are trying to give away the current inventory.
Chris
/ 2014 Chevy/GMC specs #78
Looks like GM released some specs on the 2014 1500 trucks.
2014 Silverado/Sierra Release 5.3L MPG, Power, Payload and Towing Numbers - PickupTrucks.com News
V8 5.3l direct injected, normally aspirated, EcoTec making 355 HP / 383 LB.FT. burning 87 octane with no turbos or drivetrain tricks. Nice flat torque curve plus still has that V8 sound.
4x2 - 16 city / 23 highway / 19 combined
4x4 - 16 city / 22 highway / 18 combined
11,500 lbs max towing capacity
2,102 lbs max payload
The 6.2l EcoTec will be a monster!
Here come the anti-anything-but-Ford stories...
Person writing the story was way out in left field with the higher octane making more power. Does 't seem to understand the difference between port and direct injection engines.
As for people expecting great improvements in mileage. Just what exactly are you expecting? Some engineer is going to break the laws of physics? It's still a truck on a highway at 55mph burning gasoline . The old 400 four barrel 4X4 in the mid 70's made 4-5mpg on the highway. How much more improvement do you think is left? Still only 114,100btu in a gallon of gasoline. Still an internal combustion engine.
/ 2014 Chevy/GMC specs #79
Well said. I have always felt a strong truck getting 16-18mpg was awesome!!
/ 2014 Chevy/GMC specs #80
Making a 15% improvement in mpg in just one generation change is pretty significant in today's world but I agree, not much left until downsizing or weight reductions.
