2014 Chevy/GMC specs
/ 2014 Chevy/GMC specs #21
No it's not, the 5.0l is rated at:
4x2 - 15 city / 21 highway / 17 combined
4x4 - 14 city / 19 highway / 16 combined
Even in 4x4 the new GM 5.3l beats the 2WD 5.0l I still say the 5.0l is a good engine though and if Ford goes to an aluminum frame, mileage will go up but so will price.
There are guys getting 17-18 with a 5.0 4WD.
/ 2014 Chevy/GMC specs #22
If the read world numbers prove these number correct then good for GM. But I have to think that GM's money woes is why they are sticking with a push rod V8 vs multi-cam more valves per cylinders. Who else is using cylinder shut down to get higher EPA numbers? If nobody then I would expect that all the other brands will add it just to boost their numbers as well.
GM and Ram are using cylinder cut out.
/ 2014 Chevy/GMC specs #23
I'm curious to see how the new disc brakes made by Duralast (I think that's the name) are going to be. The disc brakes I had on my 2004 were terrible. Good bit better on my 2011 though with the NHT package. I'd also like to know how the 5.3 is rated to tow 11,500 when my 2011 with the 6.2 and NHT package was only rated to tow 10,600. Maybe the disc brakes for 2014 are much larger? Is the frame all new for 2014?
/ 2014 Chevy/GMC specs #25
I always assumed that Duralast was Autozone's house brand.
And those guys will probably get 18-20 with this 5.3. It's all in the driver and environment.
I was expecting a little more considering the direct injection AND cylinder deactivation but many people with the RAM MDS and GM AFM are able to beat the highway fuel mileage rating with light foot driving.
/ 2014 Chevy/GMC specs #27
Rams MDS and GMs AFM are as finicky as the Ecoboost is when trying to get great mpgs. It takes more attention to driving style to keep the mpgs high. On average though they probably all return fairly good results.
I like the new 5.3 numbers. They are nothing great, but close to the 5.0 with more low end tq. The Ecoboost still kills the 5.3 for tq though. It's funny how all of a sudden everyone wants to talk about who gets the best MPGs. If you are an average driver, it makes little difference in the life of the truck between them all (low and mid range engines). You'll be better off buying the truck that you like or that fits your needs rather than chasing the best MPGs.
/ 2014 Chevy/GMC specs #28
Looks like GM released some specs on the 2014 1500 trucks.
2014 Silverado/Sierra Release 5.3L MPG, Power, Payload and Towing Numbers - PickupTrucks.com News
V8 5.3l direct injected, normally aspirated, EcoTec making 355 HP / 383 LB.FT. burning 87 octane with no turbos or drivetrain tricks. Nice flat torque curve plus still has that V8 sound.
4x2 - 16 city / 23 highway / 19 combined
4x4 - 16 city / 22 highway / 18 combined
11,500 lbs max towing capacity
2,102 lbs max payload
The 6.2l EcoTec will be a monster!
Here come the anti-anything-but-Ford stories...
Unfortunately they are playing the marketing game even more than usual for the truck brands. Look at the order guide and try to build a few configurations that you like. To get those bragging numbers, the perfect combination has to be configured. I know that is not unusual for any brand, but these are extreme. For example, the best selling cab style (crew cab) is not available in those max number packages. Some are limited to the 6.2 which is limited even more to certain models. Speaking of Crew Cabs, that will be the only cab style built for some time, and built only in Mexico. So all the new trucks you will see on the lots will be built in Mexico until late this year. And all crew cabs, so there will be no max packaged trucks available. It might push more buyers into 13's if they can't wait until December to get the truck they need.
Payload ratings for GM look closer to Ram than Ford now. Ford's standard payload is nearly the same as GM's max packages. Then Ford has the Max Tow package that bumps payload up approximately 500 lbs. Then you can add the HD Payload package and bump it up another 500 lbs. In the end, Ford's max payload (3100lbs) is 150% of GM's and Ram's. These heavier payloads fit my needs better, but I know most people just use their truck like an SUV these days. I would think Ford's heavier packages will decrease when they come out with a new lighter truck in a couple years. I know GM said they didn't move their shock location out because that would have required a change to the frame, which they didn't do. But I wonder with some of their other suspension advances if they improved the ride some more. I would think that would put GM and Ram ahead of Ford for 'car like ride'.
/ 2014 Chevy/GMC specs #29
Which engine are you comparing it to?
It gets BETTER economy than the competition. Plus I gaurantee the fuel mileage while towing will be much better than the Ecoboost.
Try the Eco, Hemi 8 speed, Tundra 5.7, ect.
Typical GM. 3 years late and playing catchup.
Chris
/ 2014 Chevy/GMC specs #30
Again you have absolutely nothing useful to add..
I agree.
They're typically pretty conservative with new engine releases.
So GM is conservative but Ford was not with its numbers? Stop while you can.
Chris
/ 2014 Chevy/GMC specs #31
To some here, no matter what GM does it's dismissed out of hand but everything Ford does is perfect and to be worshipped...That's pretty much why I really don't pay much attention to this thread anymore...It's a relentless anti-GM diatribe on every subject. It has grown beyond tiresome.
Do I hate GM? YES. But for the bailout, what they did to my wallet, and the company I work for. NOT THE PRODUCT. Although I feal they are on the low end when it comes to trucks. My opinion.
The problem here is this engine only puts them on par with the competition from 2011 or so. They are taking the conservative approach as usual and playing catchup when they had a chance to be innovate and a leader.
Chris
/ 2014 Chevy/GMC specs #32
Chris
At this point all we have to compare are EPA specs. Show us where any of those touch the 5.3 in fuel economy.
This is only the middle engine. Not to be compared to the top engine offerings. Compare it to the 4.7 Ram, 5.0 Ford, 4.7 Toyota and so on. It stomps most of them and beats them all.
They are now ahead in fuel economy. When the 6.2 comes out later it will have even greater power ratings than this. Someone over at Pickuptrucks.com posted dyno graphs that showed the new 5.3 making more torque at 2k than Ford's 6.2.
/ 2014 Chevy/GMC specs #33
It's actually called DuraLife and it's made by GM (not somebody else). Their Engineers developed the process:
GM Creates Recipe for Brakes That Shine
/ 2014 Chevy/GMC specs #34
“So doubling the average life expectancy of the brake rotors from 40,000 to 80,000 miles is something we think our customers will appreciate.”
I got 90,000 miles out of my rotors on my 2004 Z71 before I had to turn them and replace the brake pads. I would be pissed off if my rotors didn't last past 40,000 miles. The only excuse I could see for that is if I were towing at maximum load for 40,000 miles. Shoot, the drum brakes on my '95 Toyota lasted 139,000 miles and when I sold the truck they were still good to go!
/ 2014 Chevy/GMC specs #35
Now that's a graph I WOULD like to see-have to agree, at this point in time- have to go with epa or dyno graphs (certified by unbiased oversight) of course:thumbsup: and it does appear at least for now GM has a slight upper hand in the mileage...
/ 2014 Chevy/GMC specs #36
/ 2014 Chevy/GMC specs #37
/ 2014 Chevy/GMC specs #38
Chris
I'm not trying to bash GM but I just don't think they have the resources to invest in all new engines for their trucks. That has to take a massive amount of money. I also think it's why the Tundra and Titan are behind when it comes to fuel mileage. In Toyota's and Nissan's case it's more because of the number of sales are not that high to justify that big of an investment. For Ford they are all in. The F series is their bread and butter. They have to be at the front.
/ 2014 Chevy/GMC specs #39
I agree. Toyota's bread and butter is the Tacoma which continuously outsells the Tundra. It's gaining on the Sierra in fact!
/ 2014 Chevy/GMC specs #40
These are all new engines. They share nothing with their predecessors other than displacement.
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Frontier Quick Attach Pallet Forks (A64126)
Frontier Quick...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
