2013 Hay Season
   / 2013 Hay Season #361
A neighbor was burning trash today and let it get away from him setting one of my hay fields on fire. We were able to get it stopped before it got to the majority of the hay we had stacked. We did loose 5 bale that were setting closer to his fence. Could have been a lost worse.
   / 2013 Hay Season
First year I have ever insured my hay. Glad it got stopped before a big loss...
   / 2013 Hay Season
we are still going to try an cut 30acs.may end up waiting till it frosts an then cut it.
Its really wet here after that 9inch rain couple weeks ago and more on way this weekend,going to just throw the towel in. Good luck with yours...
   / 2013 Hay Season #364
I attempted ,to cut some today, didn't work out very well. Hooked up cutter,rode it 10 miles and just to wet,was rutting so done for the year once again:D
I hear you! Been trying to shred my pastures now for a couple weeks. Either it keeps raining or I do exactly what you did - get out there, make one or two passes and realize it's too durn wet still.
   / 2013 Hay Season #365
After you loose 50 or 60 rd bales to a fire it's not hard to justify the hay insurance premium. I keep 300 rd bales insured the yr round.
   / 2013 Hay Season #366
in the drought of 2010 our custom baler had equipment prob an burned off our 40ac meadow.an we lost all of the hay except for 5 bales on that meadow.figure we lost 40 bales min.we had to eat that lose.the custom baler didnt offer to pay for our lose.so we went into the winter with 65 bales.thankfully we made it without buying hay or culling the herd to the bone.
   / 2013 Hay Season
I have million dollar policy on all my lease places for any damages in case I have a fire when baling or fall asleep and run threw the house type stuff. Now I'm not sure if it covers crop lost but atleast if I mess someone elses place up it will cover that and my equipment. It will also cover if cows get out and someone hits them,and pays 1000 per head if I lose any. I been working with my agent and rates really not that bad,to CYA...
   / 2013 Hay Season #368
In this era I won't set my equipment on someone else's property without my million dollar liability ins policy. I had a rd baler catch fire several years back and it's sickening feeling waiting for VFD after the water fire extinguisher is EMPTY and baler & field is still burning
   / 2013 Hay Season
I have to feed hay just off a gas well location this year,we have had another 6inches and pastures are soaked. Been along time since but have baried my old tractor to the cab and had to call winch truck few days later to get it out,hope this means good hay year next year,im looking forward to starting the 2014 hay season. Maybe even add the new Kubota rake,to replace my WR22. The Kubota cutter also looks like the vicon I have maybe the curtain will fit:D.
   / 2013 Hay Season #370
a few years ago my brother had 2 bales of hay on the 7700 an stuck it to the rear axel.it was stuck so bad it stood the winch truck up on its backend a time or 2 an slammed it to the ground before it finally unstuck the tractor.
   / 2013 Hay Season #371
Hi All, it is reassuring that u folk in the northern hemisphere have the same anxious moments that we have at baling season - have to rush to cut b4 the heat spoils the pasture, then leave it lay for 5 to 7 days depending on sun and wind, then worry about it blowing around b4 baling.... just finished this season which we did in 2 parts - 1st session got a bit wet, lay for 2 weeks - average hay, second lot was perfect. 190 4ft6in X 5ft round bales from 28 acres. Best was 112 off 10 acres, sadly our biggest paddock only yielded 78 off 18 acres...but there's always next year CheersOzG
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
iDrive TDS-2010H...
2013 Ford E-350 Cargo Van (A59230)
2013 Ford E-350...
