2012 MX5100
/ 2012 MX5100
Just for the heck of it, I just called a local Mahindra dealer for a price. A new Mahindra 3550 with rear remotes, HST, 2700LB Loader capacity is 30,456 delivered to my door
/ 2012 MX5100 #22
his web site states 170 hrs, geared transmission. Which would be fine if it has a lever that lets you go from forward to reverse without having to move the gear shift. I need to call and ask about this
I think you will find it has a shuttle shift, which is what I have on my 2012 MX 5100. I absolutely love mine, just be sure to add a lot of weight to the rear end...View attachment 531736
/ 2012 MX5100 #23
Less power in both the engine and at the PTO than the MX BUT ... it has a warranty.
/ 2012 MX5100 #24
One other thing that might be considered ... The Mahindra 3550 started production in 2015 so it has tier 4 smog.
/ 2012 MX5100 #25
And just for the heck of it, you should call and get a price on a new MX and a new M5660. (closest two in comparison).
For my money....I'd take a few hundred hours on a kubota to save 8 grand over a new mahindra:2cents:
/ 2012 MX5100
true on the warranty, but a warranty cost.
The Mahindra has some EPA smog stuff, but no DPF.
Probably for the cost difference , I could add a 3rd function and buy a grapple for the Bota
/ 2012 MX5100
he says it's not actually a shuttle shift. It's a lever that lets you change directions without changing the gear ranges, but you still use the clutch.
I'm gonna try to go look at the HST tomorrow. I think that's the way I'm leaning now. Never thought about HST being a good thing, but now after thinking about my upcoming knee surgery this Friday. HST just might be the way to go
/ 2012 MX5100
LD, didn't you say the MX5100 was a heavier tractor than the L5040 ? I just looked up the specs for both
L5040..3,902lbs - 4,233lbs
3PT Lift capacity..3,860 lbs
Loader...LA844
MX5100..3,369-3,774 LBS
3PT Lift cap.....2,866 LBS
Loader... LA844
Am I missing something ?
Guess I need to look up loader specs for the two loaders .
/ 2012 MX5100 #29
No. MX and L are same tractor, the L is a deluxe....and I think a little higher 3ph rating.
But same tractor, same loader.
The M is a heavier tractor and stronger loader
/ 2012 MX5100
OK, my bad. Thanks, On the pics. he posted, (M5040) I can't make out the loader # It does have mechanical shuttle shift, and dual rear remotes.. 691 hrs for 23,900. Double the hours of the others.
/ 2012 MX5100
Well, I went and looked at the tractors today. I ended up buying the 2013 MX5100 with HST.
I would have liked to have had the larger frame tractor M5040 (691 HRS) for the same $$ with (691 HRS) but with 3 surgeries on my left knee. I just thought about having to clutch from front to back while doing loader /grapple work .
Sure hope I didn't make a mistake by not buying the larger tractor
Dealer will deliver my MX sometime next week after having a 3RD function valve installed
/ 2012 MX5100 #32
Congrats!! The HST is awesome for loader work and slow precise movements, enjoy!
/ 2012 MX5100 #33
I think you will like. Quite an upgrade from what you have now.
What was your final OTD price if you don't mind sharing?
/ 2012 MX5100
Oh yes, No doubt it's an upgrade from what I have now. I have to admit though, the little yanmar is one tough tractor .
I don't mind telling the price. It was higher than what I wanted to pay, but he sold 3 while I was there looking . He said he sells most of them as soon as he gets them in.
He sold one of them (a 60 HP) to someone out of state sight unseen. I told him I couldn't believe he could sell a used tractor sight unseen. He said he does it all the time.
Said my tractor came from a dealer in Texas.
He said the used pre emissions tractors go fast.
I gave 24,816.00 OTD delivered with kubota added 3rd function. This is probably too much, but I have been looking for a used tractor for several months, and there is just nothing out there around me.
/ 2012 MX5100
Thanks, I hope I made the choice. I wondered that about my Kubota Z turn too. LOL
/ 2012 MX5100 #36
No point in stressing about what other people pay.
It's all supply and demand which varys widely by region.
Knowing what other people pay just gives you a good baseline, but at the end of the day, the deal must have been worth it to YOU or you wouldn't have bought it.
Did you get the R1's you were after?
/ 2012 MX5100 #37
MX5100 is a great tractor. FYI, the MX5100 has a larger front tire than the L series, and that slightly larger tire is quite noticeable (in a good way) on rough terrain. Here is a photo of our L5740 and old MX5100 side-by-side, MX is on the right.
/ 2012 MX5100 #38
There is only a difference on the industrial R4's.
Not sure how kubota swings it though......
Ag (R1) options for both machines are
Rear....14.9-26 with a rolling circumference of 148
Front ...9.5-16 with a RC of 101
Making front to rear ratio of ~1.465
R4 options for the MX are
Rear 17.5L-24.....RC of 145
Front 12-16.5.....RC of 97
Ratio is close to ags at 1.494
But the R4 options for the GL (which has the SAME R1 options an same chassis so I can only assume same gearing)
Rear 17.5L-24....RC 145
Front 10-16.5.....RC of 93
Makes that ratio 1.559
Seems a bit of a stretch to me. But dont notice people complaining about the R4 Fronts being pushed along as a result.....so must still be withing the lead/lag design parameters.
I am kicking around the idea of putting R4's on the front ONLY of my MX.
Giving me 14.9-26 rears and 12-16.5 fronts. That would make the ratio 1.525.
Slowing the fronts down a tad, but not as extreme as the GL....which again I assume is the same mechanical gearing inside.
Fronts dont offer much pull anyway, so lost traction would be minimal. But the wider footprint and a heavier duty tire are what Im after. 9.5's sink in the mud doing heavy loader work alot more than 12-16.5's will
/ 2012 MX5100 #39
I really liked the 12's for loader work. In another thread someone guessed they went to the 10's on the Grand L series to make room for the cab, but I don't see that. If there was going to be interference it would be with the FEL, but the geometry of the FEL mount looked the same. I never did get around to trying the 12's on the 5740 before I sold the MX. Wish I had.
/ 2012 MX5100
No, I did not. He was willing to swap with me , but the AG's on the other tractor were about worn out, so I just took these R4's and will give them a try.
The wide R4 front tire looks like it would work best for loader work.
If I decide I need A/G's I could probably purchase some rear rims and run AG's on the rear and leave R4's on the front for loader work
