2012 Half Ton Pickup Sales
   / 2012 Half Ton Pickup Sales #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
Thought this was interesting.
   / 2012 Half Ton Pickup Sales #2
That's about the way its always been. The total sales are down from the glory days of 2005 ish but the ratios stay the same.
Chris
   / 2012 Half Ton Pickup Sales #3
I didn't realize the Tundra was that strong. I assumed it had pockets of the country that it sold well in while others that you couldn't give one away. Around here Ford is by far and away #1 in sales but I see as many Tundras as I do Chevy/ GMC trucks. But this area loves the Tacoma so I would assume that if someone with a Tacoma decides to go larger they will go to the Toyota dealership first.
   / 2012 Half Ton Pickup Sales #4
In the past, the Silverado 1500 has outsold the F150, as a large portion of F-Series sales were the Super Duty. It's only the last couple years that the F150 has started outselling the Silverado 1500.
   / 2012 Half Ton Pickup Sales #5
Add the Sierra to the Silverado and see what happens...GM has a split brand, Ford doesn't.
   / 2012 Half Ton Pickup Sales #6
I'd buy the Tundra numbers...I see them around, probably in the ratio displayed.
   / 2012 Half Ton Pickup Sales #7
   / 2012 Half Ton Pickup Sales #8
I was surprised to see how weak Nissan was. I guess that is what you have when you have a ten year old design.
Around here I see lots of Tundras. They used to be built in Princeton IN, now they are built in San Antonio TX.
   / 2012 Half Ton Pickup Sales #10
In the half-ton class, yes, GM still outsells Ford. But when you include 3/4 and 1 ton classes, Ford outsells the combination of Chevy and GMC.
March 2013 Top 15 Pickup Truck Sales - PickupTrucks.com News
And, IIRC, in the 3/4 and 1 ton classes, Ford outsells Chevy, GM, and Ram combined.
1/2 tons are the vast majority of the market...I believe this analysis was general use pickups...I don't see a fleet number either...Ford tends to flood that market at year end, at least they used to, which used to crank the numbers up (never cared enough to look into that over the last few years)...
Even with the 1 ton and 3/4's added in..The difference apx 7% (3% with the Avalanche)...Not really material...A very competitive market with each holding it's own..A good thing in my opinion.
I don't base my buying decisions on what the masses do anyway. :drink:
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
GENERAC ST20-S 2IN WATER PUMP (A52472)
GENERAC ST20-S 2IN...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
MANTIS 155B LOT NUMBER 230 (A53084)
MANTIS 155B LOT...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
