2011 Silverado issue
   / 2011 Silverado issue #1
deerefan
louisiana
1952 8N, 2005 JD 5103
I am having a weird issue with my 2011 Z71. I have noticed small grease specks under my drivers door and now the drivers side tire is showing uneven wear on the inside tread edge. I dropped it off at the dealer yesterday but no response yet. It has 33k miles. Could a bearing or hub be going out, hence the grease? Its weird. Thoughts?
   / 2011 Silverado issue #2
CV joint
   / 2011 Silverado issue #3
Bearing.
Chris
   / 2011 Silverado issue #4
Ball joint.
AKfish
   / 2011 Silverado issue #5
One of is going to be right. Lol.
Unless its leaking turn signal fluid.
Chris
   / 2011 Silverado issue #6
My guess is that they will find an "acceptable" issue. My dad bought a new GM truck. Developed a little "clunk" in the transmission during a shift sometimes. Had it looked at under warranty many times. He was told it was a known issue and there is no "fix". Open a case with corporate, came back with the same answer, that they would not put in writing. Dad still has the truck, and it stills drives perfect, just has that occasional clunk. Good Luck!
So far they found nothing. All seal and boots look good. The tire is out of balance, but I really want to know where the grease is coming from. I see it only under the driver door, not in wheel wells or under the truck.
   / 2011 Silverado issue #8
Was it rustproofed (aftermarket)?
   / 2011 Silverado issue #9
May have just ran over something.
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2025 CFG Industrial 680 (A50123)
2025 CFG...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
