2011 jd 5105m differential lock
/ 2011 jd 5105m differential lock #1
alrawluk
Moosehorn, Manitoba
2011 JD 5105M
how do you know when the diff lock is on , is there a dash light, i dont think mines working because it isnt hard to turn when i think i have it engaged ???
anyone let me know
/ 2011 jd 5105m differential lock #2
All the M's have an electro-hydraulic differential lock - except possibly the 65M. I seem to recall that the EH 3pt hitch was not available on the 65M.. Nevertheless, I believe you should see an amber colored symbol in the instrument cluster when the floor button is engaged.
AKfish
/ 2011 jd 5105m differential lock #3
AKfish
Well... I plowed snow tonight for about 4 hours. Used the differential lock - stepped on that dimmer switch - and no light. The wheels were spinning on the snow and ice - both at once! But, no light or any indicator.
Gave you bad info -- have to look in the Owner's Manual.
AKfish
/ 2011 jd 5105m differential lock #4
It should be very obvious that it is working when you steer, unless maybe you are on a sheet of ice with a puddle of oil over it. My guess is that if you don't think it's working, it probably isn't. Sorry I can't provide you with help troubleshooting. I am not familiar with the electronics of the new tractors off the top of my head. My tractor is still almost exclusively mechanical.
/ 2011 jd 5105m differential lock #5
I couldn't find anything in the manual about an indicator light. I guess if both rear tires spin you're in. I did see something about tapping one brake after you're out to make sure that it unlocked.
2020 CATERPILLAR 239D3 SKID STEER (A65053)
2020 CATERPILLAR...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
New/Unused Wolverine Quick Attach Hydraulic Concrete Chute (A65583)
New/Unused...
HONDA Plate Compactor (A64553)
HONDA Plate...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
