2011 jd 5105m differential lock
/ 2011 jd 5105m differential lock #1
alrawluk
Moosehorn, Manitoba
2011 JD 5105M
how do you know when the diff lock is on , is there a dash light, i dont think mines working because it isnt hard to turn when i think i have it engaged ???
anyone let me know
/ 2011 jd 5105m differential lock #2
All the M's have an electro-hydraulic differential lock - except possibly the 65M. I seem to recall that the EH 3pt hitch was not available on the 65M.. Nevertheless, I believe you should see an amber colored symbol in the instrument cluster when the floor button is engaged.
AKfish
/ 2011 jd 5105m differential lock #3
AKfish
Well... I plowed snow tonight for about 4 hours. Used the differential lock - stepped on that dimmer switch - and no light. The wheels were spinning on the snow and ice - both at once! But, no light or any indicator.
Gave you bad info -- have to look in the Owner's Manual.
AKfish
/ 2011 jd 5105m differential lock #4
It should be very obvious that it is working when you steer, unless maybe you are on a sheet of ice with a puddle of oil over it. My guess is that if you don't think it's working, it probably isn't. Sorry I can't provide you with help troubleshooting. I am not familiar with the electronics of the new tractors off the top of my head. My tractor is still almost exclusively mechanical.
/ 2011 jd 5105m differential lock #5
I couldn't find anything in the manual about an indicator light. I guess if both rear tires spin you're in. I did see something about tapping one brake after you're out to make sure that it unlocked.
JOHN DEERE 3025E TRACTOR (A62130)
JOHN DEERE 3025E...
2002 Lexus LS Sedan (A61569)
2002 Lexus LS...
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
New/Unused Landhonor Mini Skid Steer Pallet Forks (A61166)
New/Unused...
New/Unused Agrotk YC-32G Sawmill (A61166)
New/Unused Agrotk...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
