2011 - 3320 Cab 3 Cables behind the cab
   / 2011 - 3320 Cab 3 Cables behind the cab #1
topfox124
2011 JD 3320 Cab
Trying to slowly add missing options to my 3320 tractor. This far Ive been working on filling blanks in the operators area with their respective features. However there are 3 open plugs in the outside rear of the tractor right below the glass of the cab. Two are right in the center, and the third is closer to the left fender. Does anyone know what options these cables go to?
   / 2011 - 3320 Cab 3 Cables behind the cab #2
By "Cables" assume you mean electrical plugs.
Could be for trailer lights, working lights, etc.
Use a tester to find out when these plugs have 12v by turning ignition, lights, or other obvious switches on/off.
I used one for a work light to the rear.
   / 2011 - 3320 Cab 3 Cables behind the cab #3
G'day Mate and welcome to TBN from Downunder.
Without knowing (or a picture) of what type of plugs you're referring to we're really just guessing blind. I also used an existing two, separate, bullet-type (male/female) plug set to wire up a work light on the ROPS of my 4105... it was hard-wired (existing) to my light-switch.
If it were me, I'd take a photo or two of what you have and take it to your/a JD Dealership. Talk to the Service Dept. or one of the mechanics, it's what I did to discover that pre-existing work-light plug. My Dealership was simply happy to help.
Enjoy the site.
   / 2011 - 3320 Cab 3 Cables behind the cab #4
On my 2008 3320 open station there were two cables that I used for work lights, they had bullet connectors with if I remember right black and purple wires. I think the later tractors also had a connector for the air suspension seat, mine didn't and I had to run the wiring to the fuse box.
2017 Ford F-650 Mason Dump Truck (A56858)
2017 Ford F-650...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
XCMG CV83PD (A53317)
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2014 Ford Explorer Limited SUV (A55853)
2014 Ford Explorer...
