2010 went clank in the rear end, then went no where
   / 2010 went clank in the rear end, then went no where #1
The Farm
2010 utility
Before anyone wants to hit the 2010 is a terrible tractor band wagon, don't. I'm aware of many of their less than desirable aspects. Only paid 1k for it, so we're not out much, but it's been a decent tractor till this
Only way to move foreword is to push the diff lock handle all the way out. Right side is not driving. Outside visual inspection offers nothing
Thanks
   / 2010 went clank in the rear end, then went no where #2
You are talking about some 60 years old tractor so it must have been pretty good if it's still been used.
Sounds like it needs some rear disassembly!
   / 2010 went clank in the rear end, then went no where #4
Do both sides drive with diff lock engaged?
I would worry an axle broke and could come out.
I agree time to open it up
Only the left side drives
   / 2010 went clank in the rear end, then went no where #6
If the tractor wont move unless the differential lock is engaged, then by definition you have a broken axle.
   / 2010 went clank in the rear end, then went no where #7
Axle
   / 2010 went clank in the rear end, then went no where #8
Where are the filings from the broken axle going, into a filter or just floating through other gears and wrecking them?
   / 2010 went clank in the rear end, then went no where #9
My vote is failed differential pinion shaft(item 13) &/or gears in lieu of failed rear axle. Are you positive about model #??? JD 2010 didn't have option of differential lock.
   / 2010 went clank in the rear end, then went no where #10
It still means a rear end tear-down. I would much rather do that than a split. Still going to have some heavy parts to deal with though.
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55315)
BOSS 990 Fuel...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2020 Club Car Onward HP Li ION Electric Cart. (A56859)
2020 Club Car...
