2010 john deere diesel
/ 2010 john deere diesel #1
chad parks
mtn city tn
where to drain and refill hydraulic fluid. pictures of where it is located if possible. my hydraulic fluid looks milky. thanks if you can help. it is a diesel if that makes a difference.
/ 2010 john deere diesel #2
My dad had a 2020 on the farm. If I remember correctly the fill is just behind the seat. Not sure about the drain.
ISZ
/ 2010 john deere diesel #3
I just purchased a 1961 2010 diesel and had the same experience. The drain plug is I believe a 1 1/8 bolt on the bottom of tractor directly being the hydraulic filter. The fill bolt is also the same size below the seat on the right side of tractor. I drained the fluid, filled the Transmission with diesel (per JD mechanic) and rocked ( by hand) the tractor back and forth and drained, two times. My tractor had a screen type hydraulic filter which I cleaned and then filled with fresh hydraulic oil. I plan to operate for a few hours and drain fluid and replace.
