2010 dodge ram 2500/3500
   / 2010 dodge ram 2500/3500 #21
Right. I hear guys with stock 12 valves "P" pumping them and adding big injectors and a 7.3L Ford Intercoolers. There are a few other home brewed tricks to get them upto around 500 RWHP. If I remember right the origional Cummins in the Dodge trucks was only 160 HP but underrated and more like 200 HP but still a far cry from today's trucks.
Chris
They had some torque though. but yea 350hp and 650lb ft right now and more to come.
   / 2010 dodge ram 2500/3500 #23
There's no way he has "chips" on a 12 valve. 1 - The pump is completely mechanically controlled, it's impossible to add a "chip", 2 - There would be no point to attempt to adapt an electronically controlled pump to it as the P7100 has the ability to flow more fuel than any VP44 or CP3 ever could. 12 valves make there power the old fashioned way, all wrenching no electronics.The P7100 is a lot of the reason why people like them for pulling truck's as well.
   / 2010 dodge ram 2500/3500 #24
Exactly! You can easily gain a good amount with just injectors and a modified fuel plate but then the exhaust starts to run hot so you get into a larger turbo (or twins with some head modifications), three piece exhaust manifold and a 4" or 5" exhaust. Then you add larger delivery tubes to the P700 pump, larger fuel lines. Anyway, you can easily see 600HP and 1000 ftlb's without drugs and the amazing part is that the engine will hold together. My 12V started out with 225hp and I without actually dino'ing it, I am around 350 or so with minimal tweaking. There is a block that you have to watch out for due to poor casting. I think it is the 53 block. The number is cast on the lower left front corner.
   / 2010 dodge ram 2500/3500 #25
Back in '99-'02 I used to run up to the dyno rollers with the Cummins guys in my 7.3 powered F-450. I thought I was doing pretty good making 400RWHP, but the Cummins trucks used to blow my Ford away. They're so simple to modify with their mechanical pumps and tough bottom ends.
The cummins has always been the hot rod of diesel motors and pretty sure they always will be theres just so much more support out there for the cummins then the other 2 not that GM or Ford dont have good diesels they do GM makes a heck of a motor, ford has had some problems but there still a good motor cant wait to see the new 6.7 ford diesel.
   / 2010 dodge ram 2500/3500 #27
The DMAX may be the only one of the 3 to go past the 1000HP mark. There's one or 2 of them out there.
   / 2010 dodge ram 2500/3500 #28
1,008HP / 1,864 lb-ft - 5.9l Cummins - stock rear end and drivetrain
Heck, MadDog's 1000+hp engine package is a Cummins.
I saw a video of the 1000hp Duramax, it blew coolant out of the reservoir on the dyno when the injectors lifted.
Watching all these videos of new diesels makes me really want to sell my old 94 Ford IDI diesel. I for one would love a small V8 diesel 1/2 ton truck, even if it only comes with 200hp because it's so easy to add power when needed. A simple programmer will take a 50mpg 200hp daily driver to a 20mpg 400hp truck. That would be ideal. :cool:
   / 2010 dodge ram 2500/3500 #29
There are 1000HP Fords, GM's, and Cummins. I have seen first gen 7.3's, 5.9, and 6.5's making 600+ hp.
Chris
horse power is fun but how much do you really need I havent have anything yet that the 6.7cummins cant handle pull a kubota excavator with it at work load it full of dirt, gravel or cinders and salt in the spreader for plow and a 9ft2in Boss plow and it handles everything great, I might get rid of the 3500 if my company will give me a deal on the 5500.
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
