2010 dodge ram 2500/3500
   / 2010 dodge ram 2500/3500 #11
I bought a new Ram about 1 1/2 years ago. I looked really hard at a 2500 4x4 with a Cummins. It was way to expensive. At the time they were giving a $5000 rebate and taking almost another $5000 off. On 3/4 ton diesels they were taking about half that much off the sticker plus the truck cost alot more. It would have cost me at least $10,000 more. I think they are trying to fill that niche for people like me that want the economy of a diesel, still want to be able to tow and haul, but don't want a 3/4 ton.
   / 2010 dodge ram 2500/3500 #12
I always considered a 2500 to be a 3/4 ton and the more or less only recently available single rear wheel 3500 to be a "light duty" one ton.
I would like to update my 97 Dodge with something newer but this economy scares me so I am just trying to keep it going for now since the engine is still strong. I would not buy new regardless but the current situation gives me reason to pause about even buying another used Dodge. I see no good for buying any replacement parts that have to be Dodge sourced with Chrysler's struggle to survive and Fiat buying 35% interest.
If your looking to update from a 97 look at a 03-05 even the 06. I dont understand why people are scared to update to new trucks the emmissons arent that mad just quite. we have 3 trucks with the DPFs on them a 5500 cummins a 3500cummins and a 3500 Dmax all run great with no problems. I cant wait to see the new motors in 2010
Heres the Cummins the 3500 is mine got it real cheap has an R title but looks as good as new. and the 5500 is the companys truck but its at my house as much as the 3500. Love both of them. Normaly put grandpa in my 3500 and i run the 5500 when it snows.
   / 2010 dodge ram 2500/3500 #15
I guess I am just kicking and screaming about letting go of my old 12valve mechanical pump non computerized engine, ha! Maybe I will just keep it around for a repower since the truck is not really worth much.
Dont get me wrong the 12valve is a tryed and true motor the only thing i dont like is that it gives me a headache. thats what i like about the 6.7 lots of power and quite but not to quite.
   / 2010 dodge ram 2500/3500 #17
That 12Valve is worth more than you think. A guy down the street owns a diesel shop. They specialize in Cummins powered trucks but also do work with Powerstrokes and D-Max. Daves Diesel - Diesel Injection Service & Performance Diesel Products
Anyway I hear that the 12 Valve is a much stouter engine than the 24 valve. They are sought after to make pulling trucks and such. The guys son's personal truck is a 12 Valve making over 800HP at the rears. Atleast that is what I gather, he is very secretive but his dad is not so. I was told by his dad, the owner, it is a twin turbo, stacked chips, big injectors and pump, ect, ect, ect pulling 80psi of boost.
My guess is the engine is worth more out of the truck in the right market than a running truck is. They love to take late model 24 valve trucks and build a stout 12 valve to stick in them.
Chris
Chris
How is he running chips on a 12valve?
Also Ive heard that the new 2010 diesel will have 2 ECMs so if you try to put a DPF delete chip on them it will erase the chip.
   / 2010 dodge ram 2500/3500 #19
Not sure how he is running chips. I believe they make custom chips. I believe what they are doing is using the late model electronics and components on the 12 valve blocks. From what I gather from talking to them the 12 valve platform is much stouter than the 24 valve. Either way the Cummins is a great engine but like you said the early ones should have came with ear plugs.
Chris
Ok got yea becuase there in now way a stock 12Valve can run chips its mechanical, I bet that would make some sick power though with the chips injecters and twins.
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
Case SC Tractor (AS IS) (A50774)
Case SC Tractor...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A52748)
2012 NEW HOLLAND...
2017 Ford F-250 Enclosed Knapheide KUV Service Truck (A50323)
2017 Ford F-250...
2013 Ford F-150 (A50120)
2013 Ford F-150...
