2010 DK45 cab glow plugs
   / 2010 DK45 cab glow plugs #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
Over the years, it seemed like it was getting harder and harder to get a clean (no soot or engine clanging sounds) when starting my tractor when engine was cold. I was running 2 glow plug time sessions which helped, but lately that wasnt enough.
I finally got off my lasy butt and traced down what has been happening. When i unplugged the glow plug harness, i was getting 12 volts when i turned the key on, so relay and computer board were working correctly.
I got my service manual out to see what was involved in pulling glow plugs, and it wasnt much help. I talked to parts guy at Jordan Tractor and he kind of walked me thru it….that and asking some questions on this site.
Hardest part was removing the hood…..that sucked. I have 4 cuts on my hands alone from that. Kioti like alot of steel as they didnt skimp on the weight.
The 4 nuts securing the common rail are near microscopic and were hard for my big OLD hands to finagle, but i finally succeeded in getting them off with lock nuts without losing any. Had magnet handy just incase.
I was leery of breaking the plug off as so many people warned me about major damage if this happens, but they came loose very easily. Guess i lucked out. I had a diesel mechanic from this site (thank you DieselBound) recommend a hot engine and soak them in penetrating oil (Deep Creep)for 20 minutes. I did that.
I measured the ohms on the new ones and compaired them to the old ones. Only 1 of the old ones matched the resistance. One other had 4 times the resistance. The other 2 were open so useless. Basically i was down to 1 operating glow plug.
No wonder why it was smoking so bad.
Installed the new ones with some ceramic paste (anti sieze) and torqued them down. Reinstalling the rail sucked due to micro sized nuts, but i got it finished in pretty short time….with much cussing.
Fired up the cold engine after glow cycle…..no smoke and no noisy engine sounds. Just like when she was new.
Getting three of the glow plugs out was pretty straight forward, but of course the stupid engineers placed one out of site and under a major bracket supporting the ac compressor and fuel injector system. I had to go thru nearly my entire supply of 12mm socket and extension and wrench combinations to get that plug out. And i had about a paper width clearance left to remove socket after pulling it out. I have 4 more bruises on hands from that.
But, hopefully ill never have to mess with this item again…i hope. The others lasted nearly 15 years.
   / 2010 DK45 cab glow plugs #2
Lotsa satisfaction when a job is successfully completed!!
Can I advise you to use a cetane improver additive? You will be amazed at the reduced rattle on cold startup…
I use an additive in winter. Power Service. When the glow plugs were working years ago, i never had any issues starting. Even without any additive. I had a 30 yo dodge diesel, never had any winter start issues. Nearly 400,000 miles too. Guess the cummins diesel had better glow plugs.
The kioti plugs are bosch.
   / 2010 DK45 cab glow plugs #4
I'm a listening... Same tractor and could happen to me. HOPING not though...
In the south here we probably don't need em (glow plugs) near as much as ya'll do. Made me think, is it even worthwhile to let the glow plug light go out before starting if the temps are above 40? There are not that many days in the year when I will be out on it below 40 degrees.
The glow plugs suck down 30 amps of juice while operating. Might be hard on the starter to try starting it while there operating. Though just spitballing here.
Well, i got the glow plugs swapped out a bit ago, i forgot to update this post. Man, what a difference in starting. Like it was when it was new.
Job was not hard at all. Worst part was removing the hood. Could have used a helper, but no one was available. A few cuts later, all was good.
Two of the old glow plugs were totally shot, one was almost shot, and one was still working (according to ohming them against new ones).
   / 2010 DK45 cab glow plugs #7
Changed mine this morning. Same as above removed hood, one in front was in a tight spot.
Tested it appeared two were bad the other two not so much. Changed them all. Ready for winter.
   / 2010 DK45 cab glow plugs #8
My DK40 is starting to smoke on startup, looks like I need to make some checks. What did you folks measure for resistance on the good plugs?
Dont remember the ohms, but the open ohm readings were a dead giveaway
   / 2010 DK45 cab glow plugs #10
My DK40 is starting to smoke on startup….
That’s usually normal, especially as the weather gets cooler. Add a cetane improver and see if cold starting improves
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
Portable Restroom (A54865)
Portable Restroom...
Rooster Artwork (A55758)
Rooster Artwork...
3-4 CU/YRD PULL TYPE DIRT CARRY PAN (A58374)
3-4 CU/YRD PULL...
