2010 3032e fuel solenoid shutoff not working
   / 2010 3032e fuel solenoid shutoff not working #1
Corndiesel
2009 John Deere 3032E
2010 3032e. Won’t start. I’ve replaced the fuel solenoid shutoff, replaced the relays, replaced fuel filter and vented injectors just to name a few. I pulled the fuel solenoid shutoff and it is not retracting when I turn the key halfway. If the key is halfway and I push the solenoid in it holds until I take the key to off at which it pops out. Somehow the initial opening of the solenoid is not happening but the hold is. I have fuel. Took the fuel line off the inlet to the injector pump and it was coming out good when the lift pump was running. The seat safety switch is bypassed also. I’m thinking I might have a ground somewhere. Any suggestions on what to trouble shoot next? I’m running out of ideas and really don’t want to hunt down a ground. Thanks.
   / 2010 3032e fuel solenoid shutoff not working #2
Sure sounds like the dreaded thermister type of thing. Do a search for John Deere thermister problem and see what you find. Should be a number items out there concerning it.
Thanks for the help. I’ll give it a shot. My plans is to also replace the neutral switch. Fingers crossed.
   / 2010 3032e fuel solenoid shutoff not working #5
Load the parts Canon!
   / 2010 3032e fuel solenoid shutoff not working #6
Can you post a photo of the solenoid.
You are on the right track, it sounds like the pull-in coil is not doing it's job.
Is the solenoid a two or three wire ?
Make some ohm measurements of the coils to ground. I don't know what the readings should be, but definitely not open.
Richard
   / 2010 3032e fuel solenoid shutoff not working #7
Richard
Are you at all familiar with the John Deere thermister principle? Measurements of the coils really aren't necessary if there's no signal getting to pull coil, as is most always the problem in these cases. Testing said pull coil with a 12v jumper wire will quickly confirm whether it works or not. No resistance readings needed for that.
   / 2010 3032e fuel solenoid shutoff not working #9
Corn, did u check to see if the engine started without the solenoid.??
If it does, u can reach in the hole and push the control rack to shut it off..
CABINET (A53843)
CABINET (A53843)
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2019 Chevrolet AWD Equinox SUV (A51694)
2019 Chevrolet AWD...
2025 SDLANCH SDLE20 UNUSED Mini Excavator (A53117)
2025 SDLANCH...
