Ballast 200cx and 300cx Loader weights?
/ 200cx and 300cx Loader weights? #1
Ramairfreak98ss
Columbus, NJ
Ferris/Simplicity/John Deere
assuming its not on the tractor. How much does each one weigh? I saw another post here saying another model was 774lbs?
For trailering purposes, when all said and done for say a 3320 Model 2006 JD tractor, a 300cx loader, rear tire weights, front hood gaurds and a 55" rear pto driven JD tiller and the I-Hitch part. I would assume if the base tractor is 2900 lbs, that this sucker is well over 4000lbs? How many people here buy a rear ballast box still if they are getting something heavy for the back such as a tiller?
Can i leave the tiller on while im using the loader, or is it easier to work when there is only a ballast box on the back and take the tiller off?
/ 200cx and 300cx Loader weights? #2
The 200CX was not designed for the 3x20 tractors.
The only info I have ever found on the weight of the 300CX loader was here
I can't see any reason why you can't bomb around with the tiller attached. I do. If you are driving over bumpy terrain it can get a bit noisy, however.
/ 200cx and 300cx Loader weights? #3
200CX loader with 53" bucket (170 lbs) is 647 lbs (includes the weight of the bucket).
300CX loader with 61" bucket (190lbs) is 856 lbs (includes the weight of the bucket).
thanks guys so its around 850 or 1137? as in the other post the Garrabo guy posted? thanks
/ 200cx and 300cx Loader weights? #5
My John Deere 3120 with 300X loader, front brush guard,950 rear ballest,and 250 per side rear wheel weights. total weight is 5245 lbs.I took it to a truck scale in my town to get this weight it is much easier then guessing that is if you have a place with a truck scale. /forums/images/graemlins/grin.gif
Good luck
Matthew3120
/ 200cx and 300cx Loader weights? #6
Not sure if I was clear, but if you purchase a 300CX loader equipped with a 61" bucket it should weight a total of 856 lbs. The bucket adds 190lbs to the overall weight of that loader.
2023 Deere 317G (A64119)
2023 Deere 317G...
2014 Takeuchi TB260 Midi Excavator (A61572)
2014 Takeuchi...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
2022 Case CX145D SR Hydraulic Excavator (A61572)
2022 Case CX145D...
UNUSED X-STAR GRAVEL LEVELER (A64280)
UNUSED X-STAR...
