2008 T2220 broke in half
   / 2008 T2220 broke in half #1
The Haymaker
Benton, Maine
2008 T2220
Twitching a good sized log out of the woods by dragging it. I had the inladen forks in the air to give turning clearance and, when I lowered them, I unintentionally bounced them. The two combined stresses were more than the midsection could bear. :(
Anyone have a lead on a salvage unit? It doesn't look like this piece even shows on the fiche.
   / 2008 T2220 broke in half #2
Worthington ag parts is a large company with several locations that specializes is used equipment parts. One problem might be identifying the broken part if it doesn’t show on a parts break down.
Good luck on your search.
Thank you. Yeah, the calls begin today. It appears it may share the part with several units.
Fun little project. šŸ¤”
I found a housing at Worthington's in PA. It's supposed to ship the 15th.
No issues tearing it down, other than a steep learning curve without a service manual.
It doesn't appear anything else was damaged when the housing failed. I ordered 4 isolators that were bad on the steering column bracket and firewall, and the throwout bearing is slightly gritty, so that'll be done too.
Lot's of pictures, a few notes, and a death threat to my son if he moves any parts. ;)
   / 2008 T2220 broke in half #5
Wow, that's a lot of parts to keep track of!
   / 2008 T2220 broke in half #6
Actually doesn't look like too bad of a project. Not an easy one by any stretch but challenging enough to keep it interesting.
Have you thought of any way to reinforce the area to prevent another break?
I have. I've had the unit since new and worked it hard the whole time. There's a definite trigger here that I'll avoid recreating. :D
Everything has to be a saga.......
Got the "new" housing and Everything appeared the same. Swapped out the bearing on the 4wd shaft, added a coat of paint, installed the clutch shaft and fork. Bolted her up to the tranny.
Roll the engine back....... totally different bolt pattern and starter position. 😭
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
JOHN DEERE 245G LC EXCAVATOR (A52707)
JOHN DEERE 245G LC...
9000 (A47477)
9000 (A47477)
NEW Woods 6ft Finish Mower (A57024)
NEW Woods 6ft...
KUBOTA L4240 TRACTOR (A57192)
KUBOTA L4240...
