2008 T2220 broke in half
   / 2008 T2220 broke in half
OUCH!
Looks like you've got a winter project to keep you and your son busy.
Sigh..... I need it now for wood. :D
I'd have had it together today if I had the correct housing. :(
   / 2008 T2220 broke in half #14
Looks like you have the tools and space for the task. It's just parts, the right parts help. Not so long ago I went through similar with a broken front axle.
The difference between the original and the replacement meant I had to machine a new steering cylinder. Fortunately, I'm equipped for something like that. (Lathe, mill etc.)
When I put the snow blade on the antique Fordson, I ran the push bars all the way back to the rear axle. Including relay plates at the mid mounting pads. Breaking the casting is not big on my list of things I want to mess with. Though I have split that tractor twice in the 45 years I've had her. It's a wet clutch on the Fordson, so the throw out bearing should outlast everything else ;-)
Well..... three months in.......
I found a local guy to weld the housing. He did an absolutely beautiful job.
It took me nearly 18 hours to put it back together. Zero spare parts, I left one fitting on the block loose. Not bad for no manual. :)
Now to figure out how to bleed the hst side of things. Everything else works, but it won't move.
   / 2008 T2220 broke in half #17
Hope you got a refund on the incorrect salvage part.
I had do that to our Farmall Super M. My Bil had a large round bale on the aftermarket FEL. He was driving too fast, got to bouncing and the bell housing broke.
He was lucky he wasn't hurt much, as it was the steering wheel hit him in the chest and knocked the wind out of him.
   / 2008 T2220 broke in half #18
One of the reasons for buying a bigger tractor than you "think you need".
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
New Holland 57 3pt. Rake (A50775)
New Holland 57...
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A54756)
UNUSED SDLANCH...
UNUSED RAYTREE RMA42 HYD AUGER (A54757)
UNUSED RAYTREE...
