2008 f350 v10?
   / 2008 f350 v10? #21
Good question, I do remember them having issues with removing spark plugs.
If they break when removing them it can be a pain to finish removing them (or $$$ if it's at a shop)
HA, i found my spark plugs very easy to remove on the v10. 2 of them removed themselves with no help from me. One of them 200 miles from home. I drove home on 9 cylinders, got a helicoil, drilled it out and tapped it and put the insert in. I put a transmission funnel on the end of my shop vac to vacuum out all the bits of aluminum. It was not a fun job, but it was not terrible.
   / 2008 f350 v10? #22
A V-10 is a good pulling engine. I have one now in an excursion. I wouldn’t care to have another one in a dually. I’d rather have a V-10 over a 6.0 or a 6.4 any day. I can buy a lot of gas for the repairs the first time the diesel breaks. A dollar or sometimes $1.50 premium for diesel doesn’t help either. The 6.8 was one of the top pulling gas burners of its day and still not bad by today’s standards. Ford had a good transmission too. Ford probably had the best transmission of that day besides an Allison that only made it in one gas truck.
   / 2008 f350 v10? #23
Gasoline engines have little low-down torque. For towing, you need that and not high-rev horsepower, and even smaller Diesels are better in that respect. When Mercedes owned Chrysler their 3 litre Diesel's performance in the Chrysler pick-ups was way better than the 4.7 V8 and only slightly less than the 5.6 litre V8, with 30-35% better mileage.
Average buyer gets hung up on peak numbers. Nobody wants to run a gasser at 6000RPM to achieve max power. Diesel will do it at far lower RPM so fuel consumption is lower, engine life is much longer. Even with gas $1.00 +/- lower than diesel, if you are towing heavy, the lower gas price is gone and then some.
   / 2008 f350 v10? #24
Neighbor had a V-10 and they pulled a big horse camper unit. They had 2 extra leaf springs put in the rear to handle the weight. Ball joints and the spark plugs were the 2 main issues. His newer diesel pulls the trailer better of course.
   / 2008 f350 v10? #25
A v-10 won’t pull like a Cummins but it’s the smoothest power band gas truck I’ve had. And obviously the fuel economy sucks. It’s not what I would buy for everyday trucking. But for an occasional use truck which is what it sounds like the op wants a V10 is a good truck. A 20k diesel truck is a pile that needs frequent repairs. It doesn’t make good sense to buy a 40k or more diesel truck to save $500 a year on fuel or probably less when the V-10 will do the job.
   / 2008 f350 v10? #26
20k diesel trucks don’t exist. They're in far too much demand to sell that cheap.
You can get a 20k gas truck on any corner sales lot, but a 20k gas truck would be a pile that can’t tow anything, either
   / 2008 f350 v10? #27
He’s only wanting to tow 14k not 140k. A V-10 dually will tow that with ease. It’s going to get 8 mpg if it even gets that good but it handle that load good. You realize they put V-10s in 450s, 550s the occasional 650, and motor homes. 14k isn’t that heavy of a load.
   / 2008 f350 v10? #28
You’ll get 8MPG towing 14k on flat ground. Up hills? More like 5mpg
   / 2008 f350 v10? #29
It really boils down to do you want to spend 20k on a nice gas burner and get 5-8 mpg towing or spend 40k or more on diesel trucks to get 12 mpg towing while burning $1-1.50 more expensive fuel and have a truck saddled down with emissions garbage. 3rd option is to buy an older 20k diesel but it’s almost guaranteed you’ll spend more in repairs than just putting gas in the V-10.
   / 2008 f350 v10? #30
I have a 99 v 10 f350 ec lb 4x4 475 k miles on it. 2 original coils still on it, only engine repair was a leak in the intake manifold and spit out 2 plugs. Under 1k in total engine repair. Still a daily driver. Losing the war to rust though new bed all new doors gotta do cab Connors and rockers. It's a 2v and they say the 3v is supposed to be better.🍻
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
17201 (A55852)
17201 (A55852)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
