2008 DK 55 Injection pump problems at 500 hours
   / 2008 DK 55 Injection pump problems at 500 hours #11
good info! Do you know if there is an easy way to tell if the IP is the failure prone one or not?
   / 2008 DK 55 Injection pump problems at 500 hours #12
Short answer is no, other than it seems to affect 2006-2008 models mostly. But the same IP is used on earlier and later models (I think) so it could affect others too in small numbers. Although only some of the failures were reported here, it's a small number of failures compared to the number of Kiotis sold.
   / 2008 DK 55 Injection pump problems at 500 hours #13
Well I guess I'll keep my fingers crossed, mine is a 2008, 327 hrs
   / 2008 DK 55 Injection pump problems at 500 hours #14
I got mine back today, Kioti covered the cost of the pump, replacement work cost me $260. I think it sounds quieter.
   / 2008 DK 55 Injection pump problems at 500 hours #15
Jake, If you care to identify the year your CK was buily and the hours at IP failure, I'll add it to the spreadsheet.
Scott
   / 2008 DK 55 Injection pump problems at 500 hours #16
07 CK 25, 1st. IP less than 100 hrs., 2nd. IP 550 hrs.
   / 2008 DK 55 Injection pump problems at 500 hours #17
Where can I find the year of manufacture on the tractor?
   / 2008 DK 55 Injection pump problems at 500 hours #18
In the serial #. Post it, and we'll tell you what it means, FREE!
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58214)
2025 FUTURE X-DM43...
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A55315)
BOSS 990 Fuel...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
