2008 Cat 236B2 What is it worth?
   / 2008 Cat 236B2 What is it worth? #1
Timm250
Western KY
Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
2008 Cat 236B2 skid steer What is it worth?
I have found a 2008 Cat 236 B2 skid steer with 800 hrs. It has aux hyd. & self leveling bucket & a Cat 75 hp turbo diesel engine. What would be a good price for it?
   / 2008 Cat 236B2 What is it worth? #2
Should be around 25-26000 I have one with full cab heat a bucket and set of forks one owner 2007 New set of Tires 1168 Hours For 20,000 Call or email for more Info
Dave Kopp
509-220-2473
They are asking 13,200. It also comes with a 1 yard bucket and a new 3200 lb hay spear. They also said they would replace the quick couplings for the aux hydraulic since they have never been used and are rusted.
   / 2008 Cat 236B2 What is it worth? #4
I have a 2007, 246 enclosed cab with 2 buckets, forks and 500 hours. I thought about trading it for a track machine and they offered me 16k for it. For 16 I will just keep it.
   / 2008 Cat 236B2 What is it worth? #5
If it runs as good as it looks I'd buy it and make 7or 8 K
Starts & runs great. The bucket is a Cat bucket & it is about 5/16" thick with a double sided replaceable cutting edge. I ran it around the lot & they had a gravel pile so i scooped up a few buckets of gravel & everything seems to work fine. It would lift the full bucket of gravel with no problem.
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
2023 G Bar K Goose Neck Flat Bed (A53473)
2023 G Bar K Goose...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
