2008 Cat 236B2 What is it worth?
   / 2008 Cat 236B2 What is it worth? #1
Timm250
Western KY
Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
2008 Cat 236B2 skid steer What is it worth?
I have found a 2008 Cat 236 B2 skid steer with 800 hrs. It has aux hyd. & self leveling bucket & a Cat 75 hp turbo diesel engine. What would be a good price for it?
   / 2008 Cat 236B2 What is it worth? #2
Should be around 25-26000 I have one with full cab heat a bucket and set of forks one owner 2007 New set of Tires 1168 Hours For 20,000 Call or email for more Info
Dave Kopp
509-220-2473
They are asking 13,200. It also comes with a 1 yard bucket and a new 3200 lb hay spear. They also said they would replace the quick couplings for the aux hydraulic since they have never been used and are rusted.
   / 2008 Cat 236B2 What is it worth? #4
I have a 2007, 246 enclosed cab with 2 buckets, forks and 500 hours. I thought about trading it for a track machine and they offered me 16k for it. For 16 I will just keep it.
   / 2008 Cat 236B2 What is it worth? #5
If it runs as good as it looks I'd buy it and make 7or 8 K
Starts & runs great. The bucket is a Cat bucket & it is about 5/16" thick with a double sided replaceable cutting edge. I ran it around the lot & they had a gravel pile so i scooped up a few buckets of gravel & everything seems to work fine. It would lift the full bucket of gravel with no problem.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
Pull-Behind Rotary Brush Cutter PTO Attachment (A51691)
Pull-Behind Rotary...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2 1/2 Ton Military Truck, 6x6, 16' Flatbed (A52384)
2 1/2 Ton Military...
