New BX 2350 owner here. I inherited the machine with around 1,000 hours. The weather has been between 20 and 45 F since owning and after preheating the engine according to the table, the engine will start fine. However, the glow plug indicator remains on throughout the operation and does not turn off. I have not run it more than 15 minutes at a time since coming into possession.
Several questions:
1. Does this indicate that the glow plugs are energized or could it be just a faulty lamp? I imagine this will greatly shorten the battery life of the tractor if they are constantly energized. Is there a way to test this?
2. Quick research has shown that a faulty relay or controller could be the culprit, but most of these threads have been on L series. Does the BX have a relay and controller?
3. Can someone point me in the direction of an OEM diagram that shows what part number is needed, if I wanted to replace the relay or controller?
Thanks for the help.
Several questions:
