2007 TC30 Won't move when clutch is released
   / 2007 TC30 Won't move when clutch is released #1
TLKirkland
Guyton Georgia
New Holland TC30
I just purchased a 2007 TC30. Its in great shape and only has 300 Hrs. on it. I was using it yesterday and adjusted the seat. Now when I put it in gear and release the clutch it just sits there and won't move. If I change speeds and select a different gear it will start to roll and then stop. The engine RPMs never change. There was no grinding of the gears or fluid leaks, it just won't move. Any suggestions ?
   / 2007 TC30 Won't move when clutch is released #2
Sure you didn't bump the range lever? My 2120 is touchy about that lever's position.
Jim
No. It will only move if I change the range lever and then change gears. It will move a little but then stop. I change the gear and it rolls a little. Change the gear or range and it rolls a little. There is no grinding sounds or anything. It just refuses to move.
   / 2007 TC30 Won't move when clutch is released #4
What transmission?
Jim
I have no idea. I'm thinking the clutch freeplay is the problem. I won't be home again until Friday so I will adjust it then and try it out.
I removed the plug on the case to view the clutch and it moves back and forth to the limits of the adjustment bolt. The bolt appears to never have been adjusted. There is nothing obviously wrong. There was some material stuck in it. Something like a graphite gasket type material. It still won't move when put in gear and the clutch is released.
   / 2007 TC30 Won't move when clutch is released #7
"Material stuck" in where?
"Graphite gasket type material" - Could that be your clutch plate friction lining?
Sounds about right. There is also a gap between the plates. I can get a steel rule in there with the clutch pedal released. I'm thinking there shouldn't be a gap at all with the pedal released.
   / 2007 TC30 Won't move when clutch is released #9
Sadly correct, I think.
   / 2007 TC30 Won't move when clutch is released #10
How much freeplay to you have at the pedal?
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
UNUSED FUTURE D3T 32" EXCAVATOR HYD TILT BUCKET (A57193)
UNUSED FUTURE D3T...
2018 Isuzu FTR Landscape Dump Truck (A55852)
2018 Isuzu FTR...
UNUSED FUTURE 1 SHANK RIPPER (A57193)
UNUSED FUTURE 1...
HLA 48in. Tractor Loader Forks (A55851)
HLA 48in. Tractor...
2011 Nissan Sentra (A55853)
2011 Nissan Sentra...
