2007 TC30 Won't move when clutch is released
   / 2007 TC30 Won't move when clutch is released #1
TLKirkland
Guyton Georgia
New Holland TC30
I just purchased a 2007 TC30. Its in great shape and only has 300 Hrs. on it. I was using it yesterday and adjusted the seat. Now when I put it in gear and release the clutch it just sits there and won't move. If I change speeds and select a different gear it will start to roll and then stop. The engine RPMs never change. There was no grinding of the gears or fluid leaks, it just won't move. Any suggestions ?
   / 2007 TC30 Won't move when clutch is released #2
Sure you didn't bump the range lever? My 2120 is touchy about that lever's position.
Jim
No. It will only move if I change the range lever and then change gears. It will move a little but then stop. I change the gear and it rolls a little. Change the gear or range and it rolls a little. There is no grinding sounds or anything. It just refuses to move.
   / 2007 TC30 Won't move when clutch is released #4
What transmission?
Jim
I have no idea. I'm thinking the clutch freeplay is the problem. I won't be home again until Friday so I will adjust it then and try it out.
I removed the plug on the case to view the clutch and it moves back and forth to the limits of the adjustment bolt. The bolt appears to never have been adjusted. There is nothing obviously wrong. There was some material stuck in it. Something like a graphite gasket type material. It still won't move when put in gear and the clutch is released.
   / 2007 TC30 Won't move when clutch is released #7
"Material stuck" in where?
"Graphite gasket type material" - Could that be your clutch plate friction lining?
Sounds about right. There is also a gap between the plates. I can get a steel rule in there with the clutch pedal released. I'm thinking there shouldn't be a gap at all with the pedal released.
   / 2007 TC30 Won't move when clutch is released #9
Sadly correct, I think.
   / 2007 TC30 Won't move when clutch is released #10
How much freeplay to you have at the pedal?
UNUSED PAIR OF MINI RUBBER TRACKS (A57193)
UNUSED PAIR OF...
2022 Chevrolet Tahoe FL SUV (A55853)
2022 Chevrolet...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2005 Kubota ZD21F 60in Zero Turn Commercial Mower (A55851)
2005 Kubota ZD21F...
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2023 TAKEUCHI TL10V2 SKID STEER (A52707)
2023 TAKEUCHI...
