Buying Advice 2007 Kubota GR2100 Under 200 hours
   / 2007 Kubota GR2100 Under 200 hours #1
DeereKubota
Wicomico Church VA
JD/Kubota
New here! Was wondering what to pay for this diesel in mint condition that is garage kept and serviced twice a year? Thanks!
   / 2007 Kubota GR2100 Under 200 hours #3
No, Try E-bay, Barlows, local dealer lots, local tractor swap paper, etc. I do like that tractor/mower. Little concerned about the reviews though. Try the Kubota lawn and garden forum below. Philip.
   / 2007 Kubota GR2100 Under 200 hours #4
   / 2007 Kubota GR2100 Under 200 hours #6
I would ( Glide) steer away from them myself.
;) ......... Reversing uphill ( whilst cutting ) is the real test for a GR
transmission . If the rear wheel deactivator is not adjusted properly
and checked from time to time too , the halfshaft spline gets chewed out
( as happened to my neighbour's GR2100 ) and that's a repair that's close
to write-off ....See what you can get in X700 ( or 585 as they were called) JD for the money ; they're a better lawn mower.
   / 2007 Kubota GR2100 Under 200 hours #9
The price isn't bad if it checks out on prolonged demo ; cut an acre ,
get it hot and be happy with the trans , diff disconnecting properly on
slight turn of the the front tyres ( 20 degree' ish .... ) .Look for leaks
everywhere , and any slack in the deck pully , propshafts .
You can't go by hours clock ; it's disconnectable ! Does it squeal when
the deck piston lifts the MMM ? This is a diesel & 54" , isn't it ?
Yes 54 inch diesel. It runs well but I haven't tested it much.
CAT Skid Steer (A50322)
CAT Skid Steer...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
