Buying Advice 2007 Kubota GR2100 Under 200 hours
   / 2007 Kubota GR2100 Under 200 hours #1
DeereKubota
Wicomico Church VA
JD/Kubota
New here! Was wondering what to pay for this diesel in mint condition that is garage kept and serviced twice a year? Thanks!
   / 2007 Kubota GR2100 Under 200 hours #3
No, Try E-bay, Barlows, local dealer lots, local tractor swap paper, etc. I do like that tractor/mower. Little concerned about the reviews though. Try the Kubota lawn and garden forum below. Philip.
   / 2007 Kubota GR2100 Under 200 hours #4
   / 2007 Kubota GR2100 Under 200 hours #6
I would ( Glide) steer away from them myself.
;) ......... Reversing uphill ( whilst cutting ) is the real test for a GR
transmission . If the rear wheel deactivator is not adjusted properly
and checked from time to time too , the halfshaft spline gets chewed out
( as happened to my neighbour's GR2100 ) and that's a repair that's close
to write-off ....See what you can get in X700 ( or 585 as they were called) JD for the money ; they're a better lawn mower.
   / 2007 Kubota GR2100 Under 200 hours #9
The price isn't bad if it checks out on prolonged demo ; cut an acre ,
get it hot and be happy with the trans , diff disconnecting properly on
slight turn of the the front tyres ( 20 degree' ish .... ) .Look for leaks
everywhere , and any slack in the deck pully , propshafts .
You can't go by hours clock ; it's disconnectable ! Does it squeal when
the deck piston lifts the MMM ? This is a diesel & 54" , isn't it ?
Yes 54 inch diesel. It runs well but I haven't tested it much.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
1041 (A50459)
1041 (A50459)
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
