2007 foton 254
/ 2007 foton 254 #1
hagar16
hagar
foton 254
tractor wont turn over with key? i disconected saftey switch for clutch also check all fuses. I can use a screwdriver to start tractor when screwdriver touches starter so battery is good ? so when i try to start with key i preheat that works then turn more for start and nothing ? i also changed a few fuses just to make sure 30 amps. any suggestions?
/ 2007 foton 254 #2
YOu said you disconnected the clutch switch? That switch is a normally open switch that pressing the clutch pedal down closes, completing the circuit to the starter solenoid. If you disconnect it, you have to short the two wires together to complete the key switch circuit for starting.
/ 2007 foton 254
thks will try that
/ 2007 foton 254
It worked I connected a wire together and it works thks again !
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
16ft. T/A Utility Trailer (A64557)
16ft. T/A Utility...
2022 Tesla Model 3 Long Range AWD Sedan (A64557)
2022 Tesla Model 3...
