2007 cummins
/ 2007 cummins #11
My next truck, very nice!
Where's the pics...?
/ 2007 cummins #12
I had a 1996 Dodge Cummins. The automatic transmission is the 747 transmission. The old "Torque Flight" they used in dragsters back in the 60's. The 747 tranny and Cummins motor will tear up what it is hooked to long before the motor and transmission will fail.
/ 2007 cummins #13
Hope you have the manual transmission...
The Cummins is a great motor, but Dodge has never produced an automatic transmission that could handle it.
Most failures of Dodge automatics come from inappropriate user input, or power adders. If you drive it sensibly, (I.E., not flooring it from every stopping point where ever you go) and don't add hp too it, (anyone of the big 3's auto transmissions will start experiencing problems when you add power), than you won't have a problem. The 48re that was behind the 03 - 07 5.9's is a solid piece, and the best auto transmission available that was mated to the 5.9
Wonder how you got that nickname?:rolleyes:
To the OP: Congrats on the truck, with the proper care and maintenance that truck will last you a long time.
/ 2007 cummins #14
Just to be fair, most any transmission will incur a higher chance of failure once power is added. It's the first thing to absorb the torque shock load behind the engine itself.
No truck manufacturer is going to spend more money, even if it's $5 to add more clutch material or a bigger TC to make sure the customer can go add 200HP and still have the tranny hold together as reliably as one behind a stock motor. No, the board of directors won't like the way that affects "the bottom line".
I've seen all brands cracked open on my buddies transmission shop rebuild tables from too much torque.
You can blast apart any size trans from adding too much power.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 FORD F-150 (A60736)
2014 FORD F-150...
2017 Chevrolet Equinox SUV (A59231)
2017 Chevrolet...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Service Truck (A59230)
2016 Ford F-550...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
