2007 CK20 HST Glow Plugs
   / 2007 CK20 HST Glow Plugs #1
Mike O
Vancouver Island BC
CK20 HST 2007
The ranch I bought this past summer came with a 2007 CK20 HST; it ran fine during the warm weather. But as the overnight temp drops, starting has become problematic. I pulled the fwd glow plug and it has 124 ohms of resistant. I guess I will need to replace all of them; can the middle plug be removed without pulling the manifold? Thanks.
   / 2007 CK20 HST Glow Plugs #2
I have not looked at mine to see if there is room or not.
Rancho
CK20 HST
   / 2007 CK20 HST Glow Plugs #3
I don't know if yours has a Yanmar engine, but on my Yanmar I had to pull the intake manifold which was easy, or there was no way to change glowplugs. I got replacements at NAPA for about $10 each and was a super easy job, after the manifold was off.
Tnx; I figured as much. Did you re-use the manifold gasket or did you replace it as well?
   / 2007 CK20 HST Glow Plugs #5
When I pulled the intake manifold on my 2006 DK, the gasket broke in several spots. As a minimum, I'd have a spare on hand before starting.
   / 2007 CK20 HST Glow Plugs #6
You don't happen to remember the glow plug part number that you bought?
Polaris Ranger (A57149)
Polaris Ranger...
JRB Quick Connect 10' Rake (A57148)
JRB Quick Connect...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 1790 Planter (A59814)
John Deere 1790...
UNUSED IRANCH IREA5 HYD THUMB CLAMP (A58376)
UNUSED IRANCH...
