2006 Silverado and flasher problems
/ 2006 Silverado and flasher problems #1
budgie9
JD 2305
Can anyone help with this problem.
We have a 2006 Silverado truck, whne linked to a trailer has a problem with the indicator/flasher lights. The truck indicator/flasher lights work correctly.
If we hook up a correctly wired trailer to the truck both sets of indicator/flasher lights flash. In the manner of a hazzard switch being active.
According to our local trailer guys the wiring to the trailer is correct and it works correctly when fitted to a Ford.
The Silverado dealers tell us the truck is working correctly. But as I have stated the flashers are all working at the same time.
All other lights function correctly.
We have on the trailers a single per side, mixed function marker/stop/flasher lights
We have had to re-wire the trailer as it was found the trailer 'experts' cut wires to get the flashers working and when we had the truck headlights on, all the trailer lights went off.
Thanks for any help guys.
/ 2006 Silverado and flasher problems #2
Sounds like a ground problem to me and not a Ford vs. Chevy. Make sure to hook the trailer to the truck and pull it a liitle bit. If the lights start working you need to hook a ground wire up because it is trying to ground through the ball. Probably the trailer isn't grounded properly, but the truck plug could've lost the ground as well.
/ 2006 Silverado and flasher problems #3
The chevy (I believe) uses different bulbs for the signals/flashers and the brake lights so you most likely need a trailer light converter to eliminate the feedback from the trailer.
/ 2006 Silverado and flasher problems #4
If it is the factory connector, it isn't using the signals from the taillights. On a 2006 the trailer is controlled by completely seperate circuits. They even have their own fuses.
Thanks guys,
jwstewar
I have a feeling I read somewhere about separate/different towing electrics for this truck. I was unable to find the info again. Dealers tell me just the opposite of course and say it should work, but let us be honest they are only as good as the person you talk to.
Does anyone have the wiring for the trailer hitch for this vehicle, or the best way to get these to items to work together. maybe I could then make sense of it and get it working without too much hassle.
Thanks all
/ 2006 Silverado and flasher problems #6
Start with a for sure good ground on the trailer. I would bet the bad ground is there before it is in the truck.
/ 2006 Silverado and flasher problems #7
Here is wiring diagrams for your truck and trailer.
Untitled
Is this factory wiring on the truck or something you did yourself?
Chris
/ 2006 Silverado and flasher problems #8
Thanks guys,
jwstewar
Thanks all
I can appreciate your problem. I have a 2007 GMC Sierra that has always had problems with the left signal light. I thought it was my trailer wiring but put it off. This year I rewired my trailer and guess what. Same problem. This truck has fuses for the truck and also for the towing or trailer lights. Every time I put on the left signal it will blow the 10 amp fuse. The dealer tells me that it is the connector (after market) or the trailer. The dealer that sold me the connector has hooked it up to a test machine and says there is nothing wrong with the connector. My neighbor can connect to my trailer and it works fine. Get this! I can put a 20 amp fuse in the holder and it works fine on my truck but will blow the 10 amp(called for) fuse in an instant.
Trying to get the dealer to understand this, but not sure if I want him tearing into the harnesses on my truck.
/ 2006 Silverado and flasher problems #9
My 05 Dmax had the same issues. I had a bunch of electrical issues and they finally replaced a main wiring harness to solve the issue.
Chris
Diamondpilot
The wiring on the truck is factory. The trailer is wired by me, and I have verified the wiring on the trailer by many diagrams on the web. The ground is perfect as nothing is left to chance with the ground being taken back to the plug via a white wire for both lamps. Even connecting another heavy wire from the trailer to the truck to good earth points does nothing.
Labrat
Can you give any more details on this adaptor, I have not seen anything about this.
I am not saying it is a Chev or Ford vehicle problem, or imply anything about either vehicle I own both. I do know if I connect the trailer up to my motor home the lights work fine, as it does to another Ford F150.
What I don't understand is why it will not work with the Silverardo. There has to be something different, with the socket wiring for it not to work, what that is I don't know and would like to find out, else I can't us the Chev for towing. That is the better vehicle for doing that sort of work.
I will add, my neighbours two trailers also refuse to work in the same manner when hooked to the Silverado.
/ 2006 Silverado and flasher problems #11
I've had this problem before. My issue was in the factory trailer plug on the truck. I pulled it apart and found it to be filled with rust.
Replaced it, loaded the new one with dialetric grease and siliconed the wiring harness inlet closed to keep the salt and water out.
Start checking each of the prongs with a test light..Should become obvious.
/ 2006 Silverado and flasher problems #12
The converter is normally used when there is no factory plug. Are you going from a 7 round to a 4 flat? Or does your trailer have the 7 pin round? Or did someone tap into the tail light harness?
I would also run a separate ground with a set of jumper cables to verify it's not a grounding problem..
I've seen a bulb on the trailer with a broken filament do things like this as well.
As it was mentioned that gm does fuse everything individually so you should go through all the fuses.
/ 2006 Silverado and flasher problems #13
I would look at the 7 round plug on the rear of the truck as mentioned above. Take it apart and inspect. I find many rusted and corroded like mentioned above. Take it to the dealer and make them replace if you find this to be the issue.
Chris
Thanks guys,
You are all being most helpful.
I have tried a heavy cable to the truck for earth testing and no difference doing that.
The plugs are 7 pin, with a new socket fitted last week by the dealer and all new wiring, plugs and lamps. I have to come to the conclusion that it is something to do with the way the truck is wired. I am going to start ther investigation with the fuses as suggested. Maybe there is something wierd here I will report back if I find anything.
Testing the circuits by the dealer all show it is working as it should be. The dealer also says so, but if I ask how he knows this, he can not say he has hooked the truck to any trailer. He can only go by what his spec sheets tell him! Frustrating.
This does not get the combination working, so I will ask again if I may, if anyone has any further ideas I will be grateful.
I have seen the 7 to 4 pin adaptors so thanks for reminding me, I need to get one of these for other reasons.
Thanks all.
/ 2006 Silverado and flasher problems #15
Thanks guys,
Thanks all.
Try bringing your trailer to the dealer and ask him to hook a new vehicle up to it. If it works correctly he should understand that the problem is within your vehicle.
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
Headsight Autopilot Kit for Claas (A63117)
Headsight...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
Caterpillar Traxcavator parts books (A63117)
Caterpillar...
