2006 JD 575X - Neutral Lever
   / 2006 JD 575X - Neutral Lever #1
Beano77
IH 574, JD 1520, Cockshutt 30, MF 2607H, Ford NAA G.J.
Hello All.
I have a 575X that I need to tow a short distance on my property. For the life of me, I can not find the lever to put this thing in neutral. The internet has not been much help. Can anyone help me locate this dang thing?
Thanks!
   / 2006 JD 575X - Neutral Lever #2
I believe it is on the right side behind the rear wheel. It may or may not be marked but should rotate approx 30 degrees.
   / 2006 JD 575X - Neutral Lever #3
Beano77
Welcome to TBN
Do you have the X575 manual for your tractor ??
Oldnslo is right-on where it is located.
   / 2006 JD 575X - Neutral Lever #4
Hello All.
Thanks!
Beano77
See page 31 to move your tractor
Richard
Welcome to TBN
Here is the operators manual for your tractor
  • JD X575 Operating Manual.pdf
   / 2006 JD 575X - Neutral Lever #5
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
